So, a few weeks ago I ran into a problem, which I posted about in this forum, and I was given a workaround that allowed me to bypass the problem.
The problem was that the print wouldn't get past the gcode line "M109 S220 ; wait for temperature to be reached", despite the extruder getting hot enough. So, easy fix, just remove that line from the gcode, and heat up the bed and extruder before starting the print. However, this isn't really a fix, because I can no longer press start and walk away, I now have to wait for the bed to heat up, then turn the extruder heat on, then start the print. So a single click is now three clicks over a period of 25 minutes.
Any ideas on how I could fix this problem?
I'm running Repetier 1.0.6 on Ubuntu 14.04.
Edited 2 time(s). Last edit at 04/02/2015 06:18PM by kre8.
