Resume after Pause
May 14, 2015 04:09AM
I fried my Gen6.
I have rebuilt my Orca v4.x to run on Arduino Mega + Ramps, with Repeiter firmware. I Slice with Slicer and I print with Repetier Host.
Al works fine after loads of finetuning.
However (there is always a however moody smiley)
When I pause the print, to change filament, and I home some axes, the resume button will relocate the pause point in a very slow sped.
More than 10 seconds over a few cm. When the point of origin has been reached, the print resumes at normal speed.
Unfortunately, the hotness has lost some droop during that long transport, but I can deal with that.
Any tips why this transport phase is so slow ?
Is there a parameter for resume speed ?
Thomas
Edited 1 time(s). Last edit at 05/14/2015 04:24AM by Replace.
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: Resume after Pause
May 15, 2015 04:28AM
The host uses the speeds you have set in printer settings for the manual control. Sounds like you have the z speed also for xy.
May 16, 2015 08:38AM
Ahh, which parameter should ì lookup for that ?
May 16, 2015 01:15PM
The first one. Travel feedrate. Be carefull it is in mm/minute not per second!
June 17, 2016 11:58AM
This is an old question, but I never updated the code.
Currently I am, because I rebuilt the Orca with Mk8 extruder and e3d.
However, I can not locate the "Travel Feedrate" parameter.
Am I misinterpretating ?
How much 'first one' is it ?
is it in Configuration.h or in Printer.h ?
Please let me know a bit more specific ?
Thomas
June 17, 2016 12:14PM
Printer Settings->Printer->Travel Feed Rate directly at the top.
June 17, 2016 12:52PM
Ahhh.. it's in the HOST.
I was searching the firmware. Sorry.
What is a reasonable speed per min ?
June 17, 2016 01:01PM
6000 mm/min is ok for most. 12000 works also on most.
June 19, 2016 03:39PM
Thanks.
I made it 6000 and it works fine now thumbs up
