RH printer connect has hickups September 04, 2015 09:44AM |
Re: RH printer connect has hickups September 04, 2015 10:58AM |
Re: RH printer connect has hickups September 04, 2015 11:17AM |
Re: RH printer connect has hickups September 04, 2015 11:23AM |
Re: RH printer connect has hickups September 04, 2015 12:10PM |
Re: RH printer connect has hickups September 04, 2015 12:58PM |
Re: RH printer connect has hickups September 05, 2015 04:23AM |
Re: RH printer connect has hickups September 08, 2015 08:34AM |
Re: RH printer connect has hickups September 08, 2015 11:53AM |
Re: RH printer connect has hickups September 08, 2015 01:01PM |
Re: RH printer connect has hickups September 10, 2015 12:24PM |
Re: RH printer connect has hickups September 10, 2015 01:05PM |
Re: RH printer connect has hickups September 10, 2015 01:11PM |
Re: RH printer connect has hickups September 10, 2015 01:42PM |
19:37:01.488 : Printer reset detected - initalizing 19:37:01.488 : start 19:37:01.488 : echo: External Reset 19:37:01.488 : Marlin1.0.2 19:37:01.504 : echo: Last Updated: Sep 10 2015 15:22:53 | Author: (none, default config) 19:37:01.504 : Compiled: Sep 10 2015 19:37:01.504 : echo: Free Memory: 3762 PlannerBufferBytes: 1232 19:37:01.504 : echo:Hardcoded Default Settings Loaded 19:37:01.504 : echoteps per unit: 19:37:01.519 : echo: M92 X100.00 Y100.00 Z100.00 E140.00 19:37:01.519 : echo:Maximum feedrates (mm/s): 19:37:01.519 : echo: M203 X200.00 Y200.00 Z50.00 E25.00 19:37:01.535 : echo:Maximum Acceleration (mm/s2): 19:37:01.535 : echo: M201 X3000 Y3000 Z100 E10000 19:37:01.535 : echo:Acceleration: S=acceleration, T=retract acceleration 19:37:01.535 : echo: M204 S3000.00 T3000.00 19:37:01.551 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s) 19:37:01.551 : echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00 19:37:01.551 : echo:Home offset (mm): 19:37:01.566 : echo: M206 X0.00 Y0.00 Z0.00 19:37:01.566 : echoID settings: 19:37:01.566 : echo: M301 P22.20 I1.08 D114.00 19:37:01.675 : N1 M110 *2 19:37:01.675 : N2 M115 *4 19:37:01.675 : N3 M105 *4 19:37:01.675 : N4 M114 *3 19:37:01.675 : N5 M111 S6 *66 19:37:01.675 : N6 T0 *28 19:37:01.675 : N7 M20 *54 19:37:01.675 : N8 M80 *51 19:37:03.001 : N9 M20 *56 19:37:03.001 : echoD card ok 19:37:03.001 : ok 19:37:03.033 : FIRMWARE_NAME:Marlin V1.0.2; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000 19:37:03.033 : N10 M220 S100 *112 19:37:03.033 : ok 19:37:03.048 : ok T:44.4 /0.0 B:26.4 /0.0 T0:44.4 /0.0 @:0 B@:0 19:37:03.048 : N11 M221 S100 *112 19:37:03.048 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00 19:37:03.048 : ok 19:37:03.048 : ok 19:37:03.048 : N12 M111 S6 *116 19:37:03.048 : N13 T0 *40 19:37:03.048 : echo:Active Extruder: 0 19:37:03.048 : ok 19:37:03.048 : Begin file list 19:37:03.048 : End file list 19:37:03.048 : ok 19:37:03.048 : ok 19:37:03.048 : Begin file list 19:37:03.048 : End file list 19:37:03.064 : ok 19:37:03.064 : ok 19:37:03.064 : ok 19:37:03.064 : ok 19:37:03.064 : echo:Active Extruder: 0 19:37:03.064 : ok 19:37:04.733 : N14 M105 *50 19:37:04.733 : ok T:44.2 /0.0 B:26.2 /0.0 T0:44.2 /0.0 @:0 B@:0 19:37:07.791 : N15 M105 *51 19:37:07.791 : ok T:44.1 /0.0 B:26.4 /0.0 T0:44.1 /0.0 @:0 B@:0 19:37:10.848 : N16 M105 *48 19:37:10.942 : ok T:44.1 /0.0 B:26.1 /0.0 T0:44.1 /0.0 @:0 B@:0 19:37:13.906 : N17 M105 *49 19:37:13.937 : ok T:43.8 /0.0 B:26.3 /0.0 T0:43.8 /0.0 @:0 B@:0 19:37:16.963 : N18 M105 *62 19:37:16.963 : ok T:43.8 /0.0 B:26.4 /0.0 T0:43.8 /0.0 @:0 B@:0 19:37:20.021 : N19 M105 *63 19:37:20.021 : ok T:43.5 /0.0 B:26.4 /0.0 T0:43.5 /0.0 @:0 B@:0 19:37:23.079 : N20 M105 *53 19:37:23.266 : ok T:43.5 /0.0 B:26.3 /0.0 T0:43.5 /0.0 @:0 B@:0 19:37:26.136 : N21 M105 *52 19:37:26.136 : ok T:43.3 /0.0 B:26.4 /0.0 T0:43.3 /0.0 @:0 B@:0 19:37:29.194 : N22 M105 *55 19:37:29.287 : ok T:43.2 /0.0 B:26.2 /0.0 T0:43.2 /0.0 @:0 B@:0 19:37:32.251 : N23 M105 *54 19:37:32.454 : ok T:43.0 /0.0 B:26.3 /0.0 T0:43.0 /0.0 @:0 B@:0
Re: RH printer connect has hickups September 10, 2015 02:43PM |
Re: RH printer connect has hickups September 10, 2015 03:22PM |
Re: RH printer connect has hickups September 10, 2015 03:29PM |
Re: RH printer connect has hickups September 11, 2015 03:06AM |
Re: RH printer connect has hickups September 11, 2015 03:53AM |
Re: RH printer connect has hickups September 11, 2015 05:34AM |
Re: RH printer connect has hickups September 11, 2015 05:59AM |
Re: RH printer connect has hickups September 11, 2015 07:50AM |
Re: RH printer connect has hickups September 11, 2015 08:02AM |
Re: RH printer connect has hickups September 11, 2015 09:46AM |
Re: RH printer connect has hickups September 11, 2015 01:51PM |
Re: RH printer connect has hickups September 12, 2015 02:32AM |
Re: RH printer connect has hickups September 12, 2015 03:09AM |
Re: RH printer connect has hickups September 13, 2015 04:28AM |
