Upgraded to Repetier-Host V1.5.6, now CuraEngine not working
September 22, 2015 07:06AM
Yesterday I received an upgrade notice so I downloaded Repetier-Host V1.5.6 and installed it on my Linux machine (Linux Mint 17.2, 64-bit).
All seemed to be OK, but when I loaded a test cube STL file and attempted to slice this with the Cura engine nothing happened - R-H seemed to be trying to run Cura, but the progress bar didn't move. Eventually I had to kill the slicer.
My guess is that R-H is trying to start Cura, and failing - either it can't find it, or it's not starting properly. I tried to start R-H in a terminal window, but no error was reported.
I could do with some clues to help me diagnose this problem...
Cheers,
David
Re: Upgraded to Repetier-Host V1.5.6, now CuraEngine not working
September 22, 2015 11:38AM
The host comes with 32 and 64 bit curaengine executables in plugins/CuraEngine. Make sur eit renamed the right one on configureFirst run (you did run it right?) and also make sure it has the executeable bit set.
September 23, 2015 07:23AM
I did run configureFirst.sh - but, just in case, is it safe to re-run it?
Should be run at user level in Linux, or as superuser?
September 23, 2015 03:48PM
You can rerun any time. Superuser is not required. It uses sudo to gain root privileges when required. Requires sudo to work!
Please redownload 1.5.6 - I have added a chmod to make it executable.
September 23, 2015 05:15PM
The new version is now working! Thanks. smiling smiley
Which part did the chmod affect? I'd already changed configureFirst.sh to be executable...
September 24, 2015 02:33AM
No, I now chmod the curaengine executable.
Re: Upgraded to Repetier-Host V1.5.6, now CuraEngine not working [FIXED]
September 24, 2015 05:18PM
Ah - I understand.
Thanks for the quick fix! smiling smiley
Edited 1 time(s). Last edit at 09/25/2015 05:12AM by David J.
