Thanks!
The final implementation for those interested to get into the firmware is:
In Configuration.h:
// Define 4 points on bed
#define FEATURE_MANUALBEDCALIBRATION 1
#define MANUALBEDCALIBRATION_X1 70
#define MANUALBEDCALIBRATION_Y1 30
#define MANUALBEDCALIBRATION_X2 70
#define MANUALBEDCALIBRATION_Y2 160
#define MANUALBEDCALIBRATION_X3 220
#define MANUALBEDCALIBRATION_Y3 160
#define MANUALBEDCALIBRATION_X4 220
#define MANUALBEDCALIBRATION_Y4 30
#define MANUALBEDCALIBRATION_ZOUT 5 // It is to ward off the platform to prevent collision in the first movement
Into uilang.h:
// Into your language option
#define UI_TEXT_BED_CALIBRATION "Bed calibration"
#define UI_TEXT_WIZ_BED_CAL21 "Press next"
#define UI_TEXT_WIZ_BED_CAL22 "point P2"
#define UI_TEXT_WIZ_BED_CAL23 " < OK > "
#define UI_TEXT_WIZ_BED_CAL31 "Press next"
#define UI_TEXT_WIZ_BED_CAL32 "point P3"
#define UI_TEXT_WIZ_BED_CAL33 " < OK > "
#define UI_TEXT_WIZ_BED_CAL41 "Press next"
#define UI_TEXT_WIZ_BED_CAL42 "point P4"
#define UI_TEXT_WIZ_BED_CAL43 " < OK > "
#define UI_TEXT_WIZ_BED_CALRET1 "Press next"
#define UI_TEXT_WIZ_BED_CALRET2 "Return"
#define UI_TEXT_WIZ_BED_CALRET3 " < OK > "
#define UI_TEXT_WIZ_MOVING_1 " "
#define UI_TEXT_WIZ_MOVING_2 "Moviendo..."
#define UI_TEXT_WIZ_MOVING_3 " "
#define UI_TEXT_NOTHING " "
In uimenu.h:
// After...
#if FEATURE_RETRACTION
#if UI_ROWS >= 4
#endif
#if FEATURE_MANUALBEDCALIBRATION
#if UI_ROWS >= 4
UI_WIZARD4(ui_wiz_bed_calibration_p2, UI_ACTION_BED_CALIBRATION_P1, UI_TEXT_WIZ_BED_CAL21, UI_TEXT_WIZ_BED_CAL22, UI_TEXT_WIZ_BED_CAL23, UI_TEXT_CLICK_DONE)
UI_WIZARD4(ui_wiz_bed_calibration_p3, UI_ACTION_BED_CALIBRATION_P2, UI_TEXT_WIZ_BED_CAL31, UI_TEXT_WIZ_BED_CAL32, UI_TEXT_WIZ_BED_CAL33, UI_TEXT_CLICK_DONE)
UI_WIZARD4(ui_wiz_bed_calibration_p4, UI_ACTION_BED_CALIBRATION_P3, UI_TEXT_WIZ_BED_CAL41, UI_TEXT_WIZ_BED_CAL42, UI_TEXT_WIZ_BED_CAL43, UI_TEXT_CLICK_DONE)
UI_WIZARD4(ui_wiz_bed_calibration_return, UI_ACTION_BED_CALIBRATION_RETURN, UI_TEXT_WIZ_BED_CALRET1, UI_TEXT_WIZ_BED_CALRET2, UI_TEXT_WIZ_BED_CALRET3, UI_TEXT_CLICK_DONE)
#else
UI_WIZARD4(ui_wiz_bed_calibration_p2, UI_ACTION_BED_CALIBRATION_P1, UI_TEXT_WIZ_BED_CAL21, UI_TEXT_CLICK_DONE)
UI_WIZARD4(ui_wiz_bed_calibration_p3, UI_ACTION_BED_CALIBRATION_P2, UI_TEXT_WIZ_BED_CAL31, UI_TEXT_CLICK_DONE)
UI_WIZARD4(ui_wiz_bed_calibration_p4, UI_ACTION_BED_CALIBRATION_P3, UI_TEXT_WIZ_BED_CAL41, UI_TEXT_CLICK_DONE)
UI_WIZARD4(ui_wiz_bed_calibration_return, UI_ACTION_BED_CALIBRATION_RETURN, UI_TEXT_WIZ_BED_CALRET1, UI_TEXT_CLICK_DONE)
#endif
#endif
#if UI_ROWS >= 4
UI_WIZARD4(ui_wiz_moving, UI_ACTION_MOVING, UI_TEXT_WIZ_MOVING_1, UI_TEXT_WIZ_MOVING_2, UI_TEXT_WIZ_MOVING_3, UI_TEXT_NOTHING)
#else
UI_WIZARD2(ui_wiz_moving, UI_ACTION_MOVING, UI_TEXT_MOVING_1, UI_TEXT_NOTHING)
#endif
// After actions...:
UI_MENU_ACTIONCOMMAND(ui_menu_quick_preheat_pla,UI_TEXT_PREHEAT_PLA,UI_ACTION_PREHEAT_PLA)
UI_MENU_ACTIONCOMMAND(ui_menu_quick_preheat_abs,UI_TEXT_PREHEAT_ABS,UI_ACTION_PREHEAT_ABS)
UI_MENU_ACTIONCOMMAND_FILTER(ui_menu_bed_calibration,UI_TEXT_BED_CALIBRATION,UI_ACTION_BED_CALIBRATION,0,MENU_MODE_PRINTING)
#define UI_BED_CALIBRATION ,&ui_menu_bed_calibration
#define UI_BED_CALIBRATION_COUNT 1
// Add red words
//#define UI_MENU_QUICK {UI_MENU_ADDCONDBACK &ui_menu_home_all BABY_ENTRY ,&ui_menu_quick_speedmultiply,&ui_menu_quick_flowmultiply
UI_BED_CALIBRATION UI_TOOGLE_LIGHT_ENTRY
UI_CHANGE_FIL_ENT,&ui_menu_quick_preheat_pla,&ui_menu_quick_preheat_abs,&ui_menu_quick_cooldown,&ui_menu_quick_origin,&ui_menu_quick_stopstepper MENU_PSON_ENTRY DEBUG_PRINT_EXTRA}
//UI_MENU(ui_menu_quick,UI_MENU_QUICK,8+BABY_CNT+UI_MENU_BACKCNT+MENU_PSON_COUNT+DEBUG_PRINT_COUNT+UI_TOGGLE_LIGHT_COUNT+UI_CHANGE_FIL_CNT
+UI_BED_CALIBRATION_COUNT)
in ui.cpp:
// In int UIDisplay : : okAction(bool allowMoves)
case UI_ACTION_BED_CALIBRATION_P1: // Calibrating P1 is finished
//if(!allowMoves) return false;
popMenu(false);
pushMenu(&ui_wiz_moving, true); // Print moving...
Printer::moveToReal(MANUALBEDCALIBRATION_X2, MANUALBEDCALIBRATION_Y2, 0, 0, Printer::homingFeedrate[X_AXIS]);
Commands::waitUntilEndOfAllMoves();
pushMenu(&ui_wiz_bed_calibration_p3, true);
break;
case UI_ACTION_BED_CALIBRATION_P2: // Calibrating P2 is finished
popMenu(false);
Printer::moveToReal(MANUALBEDCALIBRATION_X3, MANUALBEDCALIBRATION_Y3, 0, 0, Printer::homingFeedrate[X_AXIS]);
pushMenu(&ui_wiz_bed_calibration_p4, true);
break;
case UI_ACTION_BED_CALIBRATION_P3: // Calibrating P3 is finished
popMenu(false);
Printer::moveToReal(MANUALBEDCALIBRATION_X4, MANUALBEDCALIBRATION_Y4, 0, 0, Printer::homingFeedrate[X_AXIS]);
pushMenu(&ui_wiz_bed_calibration_return, true);
break;
case UI_ACTION_BED_CALIBRATION_RETURN:
popMenu(false);
Printer::moveToReal(0, 0, 0, 0, Printer::homingFeedrate[X_AXIS]);
popMenu(true);
break;
#endif
// Next, in int UIDisplay : : executeAction(int action, bool allowMoves)
case UI_ACTION_BED_CALIBRATION:
popMenu(false);
pushMenu(&ui_wiz_moving, true); // Imprime en la pantalla: Moviendo...
GCode::executeFString(PSTR("G28 X0 Y0 Z0"));
Printer::setOrigin(0, 0, 0);
GCode::executeFString(PSTR("G90")); // Set absolute coordinates - por las dudas
Printer::moveToReal(0, 0, MANUALBEDCALIBRATION_ZOUT, 0, Printer::homingFeedrate[X_AXIS]);
Printer::moveToReal(MANUALBEDCALIBRATION_X1, MANUALBEDCALIBRATION_Y1, 0, 0, Printer::homingFeedrate[X_AXIS]);
pushMenu(&ui_wiz_bed_calibration_p2, true); // Imprime en la pantalla: Ir al P2
break;
In ui.h:
#define UI_ACTION_BED_CALIBRATION 1205
#define UI_ACTION_BED_CALIBRATION_P1 1206 // SOME OF THEM MAY BE GOES INTO WIZARd
#define UI_ACTION_BED_CALIBRATION_P2 1207
#define UI_ACTION_BED_CALIBRATION_P3 1208
#define UI_ACTION_BED_CALIBRATION_RETURN 1209
#define UI_ACTION_MOVING 1210
Then look for this UI_MATRIX (in all code ) and add:
#define UI_MATRIX_ACTIONS {UI_ACTION_HOME_ALL, UI_ACTION_TOP_MENU, UI_ACTION_SET_ORIGIN,
UI_ACTION_BED_CALIBRATION, UI_ACTION_BED_CALIBRATION_P1, UI_ACTION_BED_CALIBRATION_P2, UI_ACTION_BED_CALIBRATION_P3, UI_ACTION_BED_CALIBRATION_RETURN, UI_ACTION_MOVING, UI_ACTION_NEXT,\
UI_ACTION_HOME_Z, UI_ACTION_MENU_ZPOS, UI_ACTION_COOLDOWN, UI_ACTION_OK,\
UI_ACTION_HOME_Y, UI_ACTION_MENU_YPOSFAST, UI_ACTION_PREHEAT_ABS, UI_ACTION_PREVIOUS,\
UI_ACTION_HOME_X, UI_ACTION_MENU_XPOSFAST, UI_ACTION_DISABLE_STEPPER, UI_ACTION_BACK}
Regards
Tiwanacote
