Hello, I'm enthused making some modifications to the firmware.
Now, I would like to add a sub-menu called "x"to menu "Quick-menu" (Pre-heatPLA, Pre-heatABS, CoolDown,... ... , and X), and when I select it or press it, then show some actions X1,X2,X3...
//ADD SOME ACTION:
UI_MENU_ACTIONCOMMAND_FILTER(ui_menu_x1,UI_TEXT_X1,UI_ACTION_for_example_DISABLE_STEPPER1,0,MENU_MODE_PRINTING)
UI_MENU_ACTIONCOMMAND_FILTER(ui_menu_x2,UI_TEXT_X2,UI_ACTION_for_example_DISABLE_STEPPER2,0,MENU_MODE_PRINTING)
UI_MENU_ACTIONCOMMAND_FILTER(ui_menu_x3,UI_TEXT_X3,UI_ACTION_for_example_DISABLE_STEPPER3,0,MENU_MODE_PRINTING)
#define UI_X1, &ui_menu_x1
#define UI_X1_COUNT 1
#define UI_X2, &ui_menu_x2
#define UI_X2_COUNT 1
#define UI_X3, &ui_menu_x3
#define UI_X3_COUNT 1
#define UI_MENU_X {UI_MENU_ADDCONDBACK, UI_X1, UI_X2, UI_X3 }
UI_MENU(ui_menu_quick_x,UI_MENU_X,1+UI_X1_COUNT+UI_X2_COUNT+UI_X3_COUNT)
Now, How I should do to add to "quick-menu" ?
I should use: UI_MENU_SUBMENU(ui_menu_quick, UI_TEXT_QUICK_X, ui_menu_quick_x) ?????
or direct add "ui_menu_quick_x" in :
//#define UI_MENU_QUICK {UI_MENU_ADDCONDBACK &ui_menu_home_all BABY_ENTRY ,&ui_menu_quick_speedmultiply,&ui_menu_quick_flowmultiply UI_TOOGLE_LIGHT_ENTRY UI_CHANGE_FIL_ENT,&ui_menu_quick_preheat_pla,&ui_menu_quick_preheat_abs,&ui_menu_quick_cooldown,&ui_menu_quick_origin,&ui_menu_quick_stopstepper MENU_PSON_ENTRY DEBUG_PRINT_EXTRA}
//UI_MENU(ui_menu_quick,UI_MENU_QUICK,8+BABY_CNT+UI_MENU_BACKCNT+MENU_PSON_COUNT+DEBUG_PRINT_COUNT+UI_TOGGLE_LIGHT_COUNT+UI_CHANGE_FIL_CNT)
Regards!!!
