Communication timeout on Repetier Host
November 29, 2015 11:38AM
Hi to all,
by yesterday i' having a lot of "Communication timeout - reset send buffer block".
In repetitier i see strange "log" like, 27, 7 7k ecc.
When i get this error the print stop and after some seconds/minutes it start again.
Usually it stop after 30 second... later after 1 minute and so on...
Someone have had a similar issue ?
Re: Communication timeout on Repetier Host
November 30, 2015 03:41AM
I tried to make a print using another PC (with my Mac book) and all is gone fine. I've used the same cable previously used on Windows Desktop.
The print has finish without errors and in time.
In Windows (later this print) i've had the same issue. Changing USB port, rebooting the system etc etc havent had any effect.
So:
In windows i get this error
With mac (generally, another machine) all go fine.
Its possible that all USB port on Desktop are broken... ?!
November 30, 2015 07:18AM
Have you checke dif you have involuntary changed baud rate?
With that response the messages are ok, but it seems strange that same hardwore on other computer works.
You could also test if the server has the same com errors on windows.
February 18, 2016 11:30PM
I have the same problem. I read some topic and think that it can be driver problem on pc.
Translate this
Re: Новичкам. Задай вопрос - получи ответ
Сообщение Master987 » 30 авг 2015, 15:06
народ где искать проблему? :cry:
12:27:16.086 : FIRMWARE_NAME:Marlin V1.0.2; Sprinter/grbl mashup for gen6 FIRMWFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDEUID:00000000-0000-0000-0000-0000sum, Last Line: 3
12:27:16.097 : echo:Unknown command: ""
12:27:16.102 : echBegin file list
12:27:16.102 : End file list
12:27:56.202 : Communication timeout - reset send buffer block
12:27:56.212 : echo:Active Extruder: 0
Эта гадость выходит при попытки управлять принтерам в командной строке Repetier-Host после чего все продолжает работать а вот при печати принтер отрубается. Пробовал переустановить Repetier-Host толку ноль. Подключил на другой USB тоже без результата.
Добавлено спустя 1 час 35 минут 14 секунд:
в общем нашёл проблему.
И это как не странно не провод и не порты usb и даже не удлинитель 2м usb и не шкаф в котором живет принтер.
Эта HD-вебкамера Logitech C270 а если быть точным софт этой камеры. Еще не разбирался что именно драйвер или программа поскольку снес все хором и коннект с принтерам вернулся.
