Actualización Printrun/Pronterface June 25, 2013 01:06PM |
Re: Actualización Printrun/Pronterface June 25, 2013 02:22PM |
Re: Actualización Printrun/Pronterface June 28, 2013 03:50PM |
Re: Actualización Printrun/Pronterface July 10, 2013 10:09AM |
iXce: What keeps you moving the experimental branch of printrun to stable? ePoxi: experimental branch is gone, there's only master and stable now nice work by the way ¬¬ but... ePoxi: master holds new developments, and stable is a version which should be fairly stable but fairly up2date too iXce: Should I be making binaries off master ir stable now? *or* Kliment: well, master sounds fine Kliment: you were using experimental before right ? or master ? I was using experinmental, without any problems really liked the GCoDE render in 3D ePoxi: yeah, all that is in master now iXce: I was using experimental before Kliment: then master, definitely Ok Just one thing... then I should retrieve the master again ePoxi: exactly cos' when moving back from experimental , it didn't work again Kliment, iXce: thanks! I'll test the master brach, and revert back to you
