Ruido raro al hacer homing justo antes de imprimir January 04, 2014 09:47PM |
#define HOMING_FEEDRATE {50*60, 50*60, 2*60, 0} // set the homing speeds (mm/min) // Antes en Z decía 4*60 // default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,200.0*16/0.8,760*1.1} // default steps per unit for ultimaker #define DEFAULT_MAX_FEEDRATE {500, 500, 5, 25} // (mm/sec) #define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for r retracts // The speed change that does not require acceleration (i.e. the software might assume it can be done instanteneously) #define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Ruido raro al hacer homing justo antes de imprimir January 04, 2014 10:01PM |
Re: Ruido raro al hacer homing justo antes de imprimir January 04, 2014 10:11PM |
