[Problema] Endstop con Full Graphic Smart Controller
June 24, 2014 12:12PM
Buenas gente,
Ando con un problema, cuando le doy a la opcion auto home desde el LCD de la maquina, toca el endstop y sigue de largo arrastrandolo.
Mis configuraciones son:
// Uncomment the following line to enable CoreXY kinematics
// #define COREXY
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#ifndef ENDSTOPPULLUPS
  // fine Enstop settings: Individual Pullups. will be ignored if ENDSTOPPULLUPS is defined
 //  #define ENDSTOPPULLUP_XMAX
  // #define ENDSTOPPULLUP_YMAX
 //  #define ENDSTOPPULLUP_ZMAX
   #define ENDSTOPPULLUP_XMIN
   #define ENDSTOPPULLUP_YMIN
   #define ENDSTOPPULLUP_ZMIN
#endif
//#ifdef ENDSTOPPULLUPS
//  #define ENDSTOPPULLUP_XMIN
 // #define ENDSTOPPULLUP_YMIN
 // #define ENDSTOPPULLUP_ZMIN
//#endif
// The pullups are needed if you directly connect a mechanical endswitch between the signal and ground pins.
const bool X_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MIN_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool X_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Y_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
const bool Z_MAX_ENDSTOP_INVERTING = false; // set to true to invert the logic of the endstop.
#define DISABLE_MAX_ENDSTOPS
//#define DISABLE_MIN_ENDSTOPS
// Disable max endstops for compatibility with endstop checking routine
#if defined(COREXY) && !defined(DISABLE_MAX_ENDSTOPS)
#endif
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis when it's not being used.
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z true
#define DISABLE_E false // For all extruders
#define INVERT_X_DIR true    // for Mendel set to false, for Orca set to true
#define INVERT_Y_DIR false    // for Mendel set to true, for Orca set to false
#define INVERT_Z_DIR true     // for Mendel set to false, for Orca set to true
#define INVERT_E0_DIR false   // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E1_DIR false    // for direct drive extruder v9 set to true, for geared extruder set to false
#define INVERT_E2_DIR false   // for direct drive extruder v9 set to true, for geared extruder set to false
// ENDSTOP SETTINGS:
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
#define min_software_endstops false // If true, axis won't move to coordinates less than HOME_POS.
#define max_software_endstops true  // If true, axis won't move to coordinates greater than the defined lengths below.
Muchas gracias!
Re: [Problema] Endstop con Full Graphic Smart Controller
June 24, 2014 08:13PM
che y si lo haces de repetier te lo hace?
June 24, 2014 10:15PM
No, desde repetier anda de 10
June 28, 2014 03:26PM
Contamos un poco que tipo de fin de carrera tenes.
Calculo que son mecánicos.
July 11, 2014 10:44AM
Son mecanicos, pelados, sin plaquita ni nada, me parece rarisimo la verdad que en repetier ande de 10 y en la controladora no.
Perdon por la demora en contestar, saludos!
