Interfaz Touch Screen Funcionando en LA PESADA!!!! January 12, 2015 12:44PM |
1 - Expandir el file system 2 - configurar zona horaria, teclado , etc. 3 - Habilitar la cámara web si les interesa Salir y rebootear.
sudo apt-get update (si hay problemas correr: sudo apt-get update --fix-missing) sudo apt-get upgrade
sudo apt-get install apache2 php5 bc chromium-browser matchbox x11-xserver-utils unclutter mplayer mc
sudo mkdir /var/www/img
cd ~ sudo apt-get install subversion libjpeg8-dev imagemagick libav-tools cmake git clone [github.com] cd mjpg-streamer/mjpg-streamer-experimental make sudo make install
cd ~ sudo apt-get install python-pip python-dev git sudo apt-get install python-setuptools git clone [github.com] cd OctoPrint sudo python setup.py install mkdir ~/.octoprint sudo usermod -a -G tty pi sudo usermod -a -G dialout pi
sudo vi /etc/fstab
tmpfs /tmp/ tmpfs defaults,noatime,mode=1777 0 0
sudo visudoAgregar las siguientes lineas:
brftv ALL=NOPASSWD: /sbin/halt, /sbin/reboot, /sbin/poweroff www-data ALL=NOPASSWD: /sbin/halt, /sbin/reboot, /sbin/poweroff, /usr/bin/mplayer10 - Instalar el paquete de la interface
cd ~ wget [dl.dropboxusercontent.com] tar xvf home-pi_v1.3.tar cd /var/www sudo rm index.html sudo wget [dl.dropboxusercontent.com] sudo tar xvf var-www_v1.3.tar
cd ~ unzip img.zip sudo cp /home/pi/img/* /var/www/img/
cd ~ ./start_touchscreen_calibration.sh
sudo vi /usr/share/X11/xorg.conf.d/10-evdev.conf
Section "InputClass"
Identifier "evdev touchscreen catchall"
MatchIsTouchscreen "on"
MatchDevicePath "/dev/input/event*"
Option "InvertX" "true"
Driver "evdev"
EndSection
#ejemplo Option "Calibration" "minX maxX minY maxY" Option "Calibration" "214 3793 214 3984"
Driver "evdev"
EndSection
octoprint
e.j. 192.168.X.X:5000 ej: 192.168.0.107:5000 (en mi caso)
sudo vi /etc/rc.local
/bin/sleep 10 && su pi -c '/home/pi/start_octoprint.sh' &
jajaajaa|
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 12, 2015 04:42PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 12, 2015 04:53PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 12, 2015 06:26PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 12, 2015 07:12PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 12, 2015 07:35PM |
Iceflow
Grandisimo aporte compadre
Solo una duda, que LCD exacto has usado? puedes poner un enlace de tu compra?
Saludos!!
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 13, 2015 11:10AM |
/ mediaplayer xbmc etc ja) y tambien tiene sobre mano derecha el pcb todos los pines que sobran del gpio para que puedan conectarles lo que se le ocurra relay leds , cualquier cosa y tambien se pueden usar como lectura o escritura, asique tienen para hacer dulce,|
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 14, 2015 04:19PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 14, 2015 06:37PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 14, 2015 06:41PM |
SinapTec
Quedó buenisima!!! Felicitaciones!!!
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 14, 2015 07:36PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 16, 2015 12:54PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 17, 2015 02:27PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 17, 2015 02:46PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 19, 2015 03:20PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 20, 2015 07:28AM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! January 20, 2015 08:51AM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! October 26, 2016 02:55PM |
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! November 04, 2016 07:19PM |
jlrj85
Buena tarde he realizado todos los pasos al pie de la letra sin errores hasta ahorita, sin embargo inicio la raspi y carga normal, revisando la red inicia Octoprint de manera correcta, nos da acceso, control y 100% funcional, pero la interfaz no carga, inicia el raspi con la touch aunque invertida en el eje x)pero sin la interfaz al fin, saben si necesito realizar algo mas para que me cargue chromium de manera automática al iniciar el sistema, les agradecere su apoyo. saludos.
En definitiva el archivo 10-evdev.conf te queda asi:
Driver "evdev"
EndSection
Re: Interfaz Touch Screen Funcionando en LA PESADA!!!! November 06, 2016 09:12PM |
Moderator Registered: 14 years ago Posts: 367 |
