autonivelacion mal configurada January 25, 2015 10:00PM |
#define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line) #ifdef ENABLE_AUTO_BED_LEVELING // There are 2 different ways to pick the X and Y locations to probe: // - "grid" mode // Probe every point in a rectangular grid // You must specify the rectangle, and the density of sample points // This mode is preferred because there are more measurements. // It used to be called ACCURATE_BED_LEVELING but "grid" is more descriptive // - "3-point" mode // Probe 3 arbitrary points on the bed (that aren't colinear) // You must specify the X & Y coordinates of all 3 points #define AUTO_BED_LEVELING_GRID // with AUTO_BED_LEVELING_GRID, the bed is sampled in a // AUTO_BED_LEVELING_GRID_POINTSxAUTO_BED_LEVELING_GRID_POINTS grid // and least squares solution is calculated // Note: this feature occupies 10'206 byte #ifdef AUTO_BED_LEVELING_GRID // set the rectangle in which to probe #define LEFT_PROBE_BED_POSITION 15 #define RIGHT_PROBE_BED_POSITION 100 #define BACK_PROBE_BED_POSITION 150 #define FRONT_PROBE_BED_POSITION 20 // set the number of grid points per dimension // I wouldn't see a reason to go above 3 (=9 probing points on the bed) #define AUTO_BED_LEVELING_GRID_POINTS 2 #else // not AUTO_BED_LEVELING_GRID // with no grid, just probe 3 arbitrary points. A simple cross-product // is used to esimate the plane of the print bed #define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 20 #define ABL_PROBE_PT_3_X 170 #define ABL_PROBE_PT_3_Y 20 #endif // AUTO_BED_LEVELING_GRID // these are the offsets to the probe relative to the extruder tip (Hotend - Probe) #define X_PROBE_OFFSET_FROM_EXTRUDER -27 #define Y_PROBE_OFFSET_FROM_EXTRUDER -4 #define Z_PROBE_OFFSET_FROM_EXTRUDER -1.89 // actual es x27.00 y 4.00 z1.89 #define Z_RAISE_BEFORE_HOMING 4 // (in mm) Raise Z before homing (G28) for Probe Clearance. // Be sure you have this distance over your Z_MAX_POS in case #define XY_TRAVEL_SPEED 8000 // X and Y axis travel speed between probes, in mm/min #define Z_RAISE_BEFORE_PROBING 15 //How much the extruder will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 5 //How much the extruder will be raised when traveling from between next probing points //#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell //#define SLED_DOCKING_OFFSET 5 // the extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like. //If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk //The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it. // You MUST HAVE the SERVO_ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile. #define PROBE_SERVO_DEACTIVATION_DELAY 600 //If you have enabled the Bed Auto Leveling and are using the same Z Probe for Z Homing, //it is highly recommended you let this Z_SAFE_HOMING enabled!!! #define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area. // When defined, it will: // - Allow Z homing only after X and Y homing AND stepper drivers still enabled // - If stepper drivers timeout, it will need X and Y homing again before Z homing // - Position the probe in a defined XY point before Z Homing when homing all axis (G28) // - Block Z homing only when the probe is outside bed area. #ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT (X_MAX_LENGTH/2) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT (Y_MAX_LENGTH/2) // Y point for Z homing when homing all axis (G28) #endif #endif // ENABLE_AUTO_BED_LEVELING
// Custom M code points #define CUSTOM_M_CODES #ifdef CUSTOM_M_CODES #define CUSTOM_M_CODE_SET_Z_PROBE_OFFSET 851 #define Z_PROBE_OFFSET_RANGE_MIN -15 #define Z_PROBE_OFFSET_RANGE_MAX -5 #endif
#define NUM_SERVOS 1 // Servo index starts with 0 for M280 command // Servo Endstops // // This allows for servo actuated endstops, primary usage is for the Z Axis to eliminate calibration or bed height changes. // Use M206 command to correct for switch height offset to actual nozzle height. Store that setting with M500. // #define SERVO_ENDSTOPS {-1, -1, 0} // Servo index for X, Y, Z. Disable with -1 #define SERVO_ENDSTOP_ANGLES {0,0, 0,0, 0,160} // X,Y,Z Axis Extend and Retract angles // park 90
Re: autonivelacion mal configurada January 26, 2015 07:29AM |
Re: autonivelacion mal configurada January 26, 2015 07:38AM |
Re: autonivelacion mal configurada January 26, 2015 07:57AM |
luismanson
Vos me estas diciendo que me mande una cagada muy obvia?
Marlin solía tener una opción para asignar un pin...yo use en su momento max-andstop, asi conserve el min, pero ahora no tengo opcion ¬¬
Re: autonivelacion mal configurada January 26, 2015 10:14AM |
M280 P0 S0 (S0 S90 es el angulo)
M401 - Lower z-probe if present M402 - Raise z-probe if present
#define ENABLE_AUTO_BED_LEVELING #define ENABLE_AUTO_BED_COMPENSATION // Delete the comment to enable (remove // at the start of the line) #define Z_PROBE_REPEATABILITY_TEST // If not commented out, Z-Probe Repeatability test will be included if Auto Bed Compensation is Enabled. #ifdef ENABLE_AUTO_BED_COMPENSATION // There are 2 different ways to pick the X and Y locations to probe: // - "grid" mode // Probe every point in a rectangular grid // You must specify the rectangle, and the density of sample points // This mode is preferred because there are more measurements. // It used to be called ACCURATE_BED_COMPENSATION but "grid" is more descriptive // - "3-point" mode // Probe 3 arbitrary points on the bed (that aren't colinear) // You must specify the X & Y coordinates of all 3 points #define AUTO_BED_COMPENSATION_GRID // with AUTO_BED_COMPENSATION_GRID, the bed is sampled in a // AUTO_BED_COMPENSATION_GRID_POINTSxAUTO_BED_COMPENSATION_GRID_POINTS grid // and least squares solution is calculated // Note: this feature occupies 10'206 byte #ifdef AUTO_BED_COMPENSATION_GRID // set the rectangle in which to probe #define LEFT_PROBE_BED_POSITION 5 #define RIGHT_PROBE_BED_POSITION 155 #define BACK_PROBE_BED_POSITION 120 #define FRONT_PROBE_BED_POSITION 0 // set the number of grid points per dimension // I wouldn't see a reason to go above 3 (=9 probing points on the bed) #define AUTO_BED_COMPENSATION_GRID_POINTS 3 #else // not AUTO_BED_COMPENSATION_GRID // with no grid, just probe 3 arbitrary points. A simple cross-product // is used to esimate the plane of the print bed #define ABL_PROBE_PT_1_X -60 #define ABL_PROBE_PT_1_Y 0 #define ABL_PROBE_PT_2_X 50 #define ABL_PROBE_PT_2_Y 145 #define ABL_PROBE_PT_3_X 0 #define ABL_PROBE_PT_3_Y 93 #endif // AUTO_BED_COMPENSATION_GRID // these are the offsets to the probe relative to the extruder tip (Hotend - Probe) #define X_PROBE_OFFSET_FROM_EXTRUDER -25 #define Y_PROBE_OFFSET_FROM_EXTRUDER -42.6 #define Z_PROBE_OFFSET_FROM_EXTRUDER -1.55 #define Z_RAISE_BEFORE_HOMING 3 // (in mm) Raise Z before homing (G28) for Probe Clearance. // Be sure you have this distance over your Z_MAX_POS in case #define XY_TRAVEL_SPEED 3500 // X and Y axis travel speed between probes, in mm/min #define Z_RAISE_BEFORE_PROBING 3 //How much the extruder will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 2 //How much the extruder will be raised when traveling from between next probing points //#define Z_PROBE_SLED // turn on if you have a z-probe mounted on a sled like those designed by Charles Bell //#define SLED_DOCKING_OFFSET 5 // the extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like. //If defined, the Probe servo will be turned on only during movement and then turned off to avoid jerk //The value is the delay to turn the servo off after powered on - depends on the servo speed; 300ms is good value, but you can try lower it. // You MUST HAVE the SERVO_ENDSTOPS defined to use here a value higher than zero otherwise your code will not compile. #define PROBE_SERVO_DEACTIVATION_DELAY 600 //If you have enabled the Bed Auto Compensation and are using the same Z Probe for Z Homing, //it is highly recommended you let this Z_SAFE_HOMING enabled!!! #define Z_SAFE_HOMING // This feature is meant to avoid Z homing with probe outside the bed area. // When defined, it will: // - Allow Z homing only after X and Y homing AND stepper drivers still enabled // - If stepper drivers timeout, it will need X and Y homing again before Z homing // - Position the probe in a defined XY point before Z Homing when homing all axis (G28) // - Block Z homing only when the probe is outside bed area. #ifdef Z_SAFE_HOMING #define Z_SAFE_HOMING_X_POINT (80) // X point for Z homing when homing all axis (G28) #define Z_SAFE_HOMING_Y_POINT (50) // Y point for Z homing when homing all axis (G28) #endif #endif // ENABLE_AUTO_BED_COMPENSATION
// Number of servos // // If you select a configuration below, this will receive a default value and does not need to be set manually // set it manually if you have more servos than extruders and wish to manually control some // leaving it undefined or defining as 0 will disable the servo subsystem // If unsure, leave commented / disabled // #define NUM_SERVOS 1 // Servo index starts with 0 for M280 command // Servo Endstops // // This allows for servo actuated endstops, primary usage is for the Z Axis to eliminate calibration or bed height changes. // Use M206 command to correct for switch height offset to actual nozzle height. Store that setting with M500. // #define SERVO_ENDSTOPS {-1, -1, 0} // Servo index for X, Y, Z. Disable with -1 #define SERVO_ENDSTOP_ANGLES {0,0, 0,0, 82,0} // X,Y,Z Axis Extend and Retract angles
Re: autonivelacion mal configurada January 26, 2015 01:49PM |
Re: autonivelacion mal configurada January 26, 2015 02:06PM |
Re: autonivelacion mal configurada January 26, 2015 06:15PM |
Re: autonivelacion mal configurada January 27, 2015 08:08PM |
G28 ; home all axes G29 ; autonivelacion M190 S[first_layer_bed_temperature] ; start y wait bed heating M300 S400 P600; beep M300 S500 P700; beep G1 Z0 M109 S[first_layer_temperature] M300 S1400 P200; beep M300 S1500 P200; beep M300 S2500 P500; beep M117 Esperamos 5s... G4 P5000 ; esperemos 5 segundos por si te colgaste ;G1 Z5 F5000 ; NO lift nozzle
Re: autonivelacion mal configurada February 21, 2015 08:57PM |
Re: autonivelacion mal configurada October 02, 2015 05:09PM |
