David Scanner welcher Beamer. 20. November 2013 12:29 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 22 |
Re: David Scanner welcher Beamer. 20. November 2013 13:04 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 308 |
Re: David Scanner welcher Beamer. 20. November 2013 13:56 |
Re: David Scanner welcher Beamer. 20. November 2013 14:30 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 1.916 |
Can I use my projector model xxx?
Yes, probably. The projector must be connected to the PC via VGA or HDMI. It must be configured as 2nd screen (“extended desktop”).
The projector should fit to the scanned object size. Most projectors can be focussed to large screen sizes only, starting at 1 meter. With these projectors you cannot focus on small objects. On the other hand, a micro projector does not have enough power to illuminate a large object (also depends on the environment light).
LCD projectors are usually easy to use. Other types (DLP, LED) require long exposure times in the camera (usually 1/60s), so it's best to have a camera with a mechanic lens aperture.
Re: David Scanner welcher Beamer. 21. November 2013 07:28 |
Re: David Scanner welcher Beamer. 21. November 2013 07:56 |
