Re: Variant of Goopyplastic's Tantillus Variant October 20, 2013 11:48PM |
Re: Variant of Goopyplastic's Tantillus Variant October 21, 2013 03:34PM |
Re: Variant of Goopyplastic's Tantillus Variant October 22, 2013 04:31AM |
Re: Variant of Goopyplastic's Tantillus Variant November 03, 2013 05:52PM |
Re: Variant of Goopyplastic's Tantillus Variant November 03, 2013 09:41PM |
Re: Variant of Goopyplastic's Tantillus Variant November 04, 2013 04:01PM |
Re: Variant of Goopyplastic's Tantillus Variant November 05, 2013 03:23AM |
Re: Variant of Goopyplastic's Tantillus Variant November 05, 2013 03:09PM |
jimjimma
So, yesterday I got the Ingentis printing.
This was the second thing I printed (first was a claibration cube)- very happy that it just worked. Printed at 70mm/s perimeters, 0.14mm layers, 15% infill.
Video here
You may see the bottom of the print looks a bit munted (kiwi term for f*cked), Y axis skipped due to current being too low before I adjusted it. Z axis belt drive works well although I need to put some really deep divots in the drive shaft to prevent the big cog from slipping.
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: Variant of Goopyplastic's Tantillus Variant November 06, 2013 04:49PM |
Sublime
Looks good. Are you using any of the Tantillus software? Tantillus Marlin? Kisslicer and Tantillus profiles? Tantillus Calculator?
Have you done anymore printing with it? Would love to see more pics.
Also the build guide is looking good. One thing that may need attention is I looked at the page a few times before even noticing the drop down at the top to the other pages so I only saw the first page.
Re: Variant of Goopyplastic's Tantillus Variant November 06, 2013 11:07PM |
jimjimma
I've been using the Tantillus calculator for ages - useful for all printers in my experience.
jimjimma
I didn't bother with Tantillus Marlin as I'm not usign a J-head, and there are enough differences to make a vanilla marlin build appropriate.
jimjimma
My usual Kisslicer profiles seemed to work well - need to fiddle the max/min flow rates though
jimjimma
I'ts been out of action for the past day or 2 as I've been dealing with a minor extruder related issue. Then I got half way through a print last night (using repetier to push the g-code) and repetier crashed. Will stick it on the SD card and try again tonight. The half finished print was very nice though, the belt z drive works very nicely (apart from when it drops like a lead weight).
jimjimma
Thanks again for all you help here Sublime.
Re: Variant of Goopyplastic's Tantillus Variant November 07, 2013 04:22PM |
Re: Variant of Goopyplastic's Tantillus Variant November 07, 2013 05:35PM |
Re: Variant of Goopyplastic's Tantillus Variant November 07, 2013 06:30PM |
Re: Variant of Goopyplastic's Tantillus Variant November 07, 2013 08:22PM |
Re: Variant of Goopyplastic's Tantillus Variant November 07, 2013 10:21PM |
acrux
Re the Tantillus calculator, I have seen it and wondered if it could be of use on my current Prusa i3. However can someone point me to postings that go into some detail of all the settings like XJ jerk etc and talk about a systematic way to get values that are appropriate for your hardware? I think I am getting good prints from good luck rather than good management. It is confusing as there seems to be settings in Marlin, Kisslicer and the start g-code I have in kisslicer that all fight each other.
acrux
OMG the four headed monster is almost awakened. I would love to play with one of these. Are there any controller boards that can control four hot ends at once? I think the one I have from gadgets3d can do two.
Re: Variant of Goopyplastic's Tantillus Variant November 08, 2013 06:13PM |
jimjimma
Damn, just realised that image I posted wasn't publicly accesible. Try again.
Re: Variant of Goopyplastic's Tantillus Variant November 10, 2013 10:54PM |
Re: Variant of Goopyplastic's Tantillus Variant November 11, 2013 08:27PM |
Sublime
The settings for the machine in Marlin are a bit harder. You want the acceleration and jerk as high as you can have them reliably. This is because the more instantaneously you can get up to speed the higher the definition you get. But they are hard to figure out because one kind of overrides the other so it just takes a lot of trial and error to find a good set of numbers. This higher is better applies to all machines but with them too high on a Mendel variant you end up with "ringing" or "ghost" patterns near corners because of the high rate of direction change and the large moving mass of the bed and extruder carriage.
Sublime
You also want the firmware's max speeds all set to the actual reliable maximum speed your machine can handle for all types of prints. This will allow you to have the shortest non-printing moves. Then set the speeds for travel and Z speed in the slicer to these same max speeds. With the max set in the firmware you can always travel at the max reliable speed even if you increase the print speed via an LCD controller.
Sublime
Last thing you want is the E settings in the firmware to be the very max they can be reliably. Tantillus has the default and max E acceleration set to 10,000 which is the max before Marlin does something strange and reduces the acceleration back to the minimum. The jerk is also set really high at 100mm/s.
Re: Variant of Goopyplastic's Tantillus Variant November 11, 2013 08:41PM |
Re: Variant of Goopyplastic's Tantillus Variant November 12, 2013 12:15AM |
jimjimma
Sublime
I'm running 20mm/s jerk and 1500 default accel at this stage but I shall push the accel up once I'm happy I've got everything working. I've strated to see Ultimaker 2 prints beign poseted and the quality and dimentional accuracy they are producing is amazing. The 'secretmarlin' repository has all the default Ultimaker2 settings - I see they have jerk at 20 and default accel at 5000.
jimjimma
Sublime
I'm still struggling to establish a way to define a 'reliable' maximum and minumum rate. I assume free air extrusion is not the best way of doign this. Also, maximum flowrate is constrained by the temperature you're printing at too eh? I see that marlin has an autotemp setting in advance.h whereby it calculates extrusion temp based upon buffered gcode as well as a setting dynamically varying altering PID power based upon extrusion speed. Any tips here would be awesome - I'm using E3d so, the numbers will be quite different from a J-Head I think.
jimjimma
Sublime
I see that the Ultimaker2 Max accel is 10,000 too but their e-jerk is only 5mm/s. I get the feeling you've proven your settings work well for a Gregs style geared extruder. What retract accel are you using?
I'm playing around with Kisslicer profiles at present. Got your ones loaded in as a starting point and will tweak things from there.
Re: Variant of Goopyplastic's Tantillus Variant December 02, 2013 06:36PM |
Re: Variant of Goopyplastic's Tantillus Variant December 06, 2013 02:21AM |
Re: Variant of Goopyplastic's Tantillus Variant December 15, 2013 12:01PM |
Re: Variant of Goopyplastic's Tantillus Variant December 15, 2013 06:25PM |
Finch
Hello All.
I have decided to build this printer. I started to print parts. I noticed that "Shaft Bearing Mounts" have apertures on the both sides. One is for inserting the bearing, I cant figure out why the bigger on the apposite side is for? On the pictures of the printer there is also only one aperture for bearing. So am a bit confused.
Thanks for answers.
Re: Variant of Goopyplastic's Tantillus Variant December 15, 2013 07:41PM |
jimjimma
Any problems, message me via google plus +tim rastall.
Re: Variant of Goopyplastic's Tantillus Variant December 15, 2013 07:46PM |
Re: Variant of Goopyplastic's Tantillus Variant December 15, 2013 08:53PM |
Sublime
Is there any way for anyone to contact you that does not involve handing over all your personal information to big brother (Google +). I for one have stopped using most of Googles services (other than search) because of them trying to force people to use their social networking service. You can't even comment on your own videos in Youtube with handing over your private info.
. I'm too imbedded in the Google machine already and G+ (for me anyway) is a good compromise between forum and social network - the 3d pritning community in particular is awesome.Quote
Sublime
Yeah sorry for the long post. Sometimes I start typing and when I look up there are paragraphs.
The Kraken looks good. Have you seen Bobc's ext6 board to add up to 6 stepper drivers and temp control circuits?
Are you doing much printing with it yet? .
Re: Variant of Goopyplastic's Tantillus Variant December 22, 2013 12:29PM |
Re: Variant of Goopyplastic's Tantillus Variant December 29, 2013 12:40AM |
karabas
Will you place extruders above the box to make bowdens shorter?
like this [www.calumdouglas.ch]
