back to direct drive Nema14
December 16, 2012 09:18PM
I'm trying something on the Foldarap #000...
After having considered to have manufactured custom geared motors like the PG35L but with better specs ( [forums.reprap.org] ), I'm now going back to the original idea : direct drive nema14.
Because there was something that I should have tried at that time when I switched to the PG35L : just raise the driver current. (when the nema14 was starting to skip steps).
And on video : [www.youtube.com]
This need more testing to be confirmed but everything seems good so far grinning smiley
I raised the Vref current of the pololu from 0.4v to 0.45v (= from 1A to 1.13A to the motor)
And I'm printing at the same speed as with the PG35L, but with the lightning retractions that I like on direct drive setups.
I was stuck at 25mm/s during the early tries with a direct drive nema14, then up to 70mm/s with the pg35l and not tested above, so this is a jump from 25 to 50mm/s for this new try.
For the print settings :
; generated by Slic3r 0.9.7 on 2012-12-17 at 01:45:50
; Marlin-RC2
; absolute X Y Z E
; 140 E-step-mm
; 195°C / 52°C
; layer_height = 0.25
; perimeters = 2
; top_solid_layers = 0
; bottom_solid_layers = 0
; fill_density = 0
; perimeter_speed = 50
; infill_speed = 45
; travel_speed = 200
; scale = 1
; nozzle_diameter = 0.5
; filament_diameter = 1.70
; extrusion_multiplier = 1
; perimeters extrusion width = 0.48mm
; infill extrusion width = 0.49mm
; first layer extrusion width = 0.50mm
Also, I'm not used to play with acceleration settings, so I copied some that I found in an Orca firmware I had around.
I may try to go higher then smiling smiley
#define DEFAULT_AXIS_STEPS_PER_UNIT   {80, 80, 3200, 140}  // FoldaRap 1200 for PG35L
#define DEFAULT_MAX_FEEDRATE          {500, 500, 5, 45}    // (mm/sec)
#define DEFAULT_MAX_ACCELERATION      {9000,9000,50,5000}    // X, Y, Z, E maximum start speed for accelerated moves.
#define DEFAULT_ACCELERATION          3000    // X, Y, Z and E max acceleration in mm/s^2 for printing moves  // 1500
#define DEFAULT_RETRACT_ACCELERATION  3000   // X, Y, Z and E max acceleration in mm/s^2 for r retracts // 1200 for PG35L
#define DEFAULT_XYJERK                20.0    // (mm/sec)
#define DEFAULT_ZJERK                 0.4     // (mm/sec)
#define DEFAULT_EJERK                 5.0    // (mm/sec) // 1 for PG35L
For the exact setup :
Nema14 : 35STH36-1004A from LDO-motors
Drive gear : stainless-steel insert from mendel-parts
Idler bearing : a rubber-roller salvaged from a Stratasys cartridge (I added a spray of PTFE to the printed idler)
And the spring was almost not compressed.
This. Looks. Promising. (at least from my point of view)
grinning smiley
about // liberapay // flickr // wiki // thingiverse - github
Re: back to direct drive Nema14
December 18, 2012 07:49PM
More videos :
[www.youtube.com]
[youtu.be]
[youtu.be]
[youtu.be]
[youtu.be]
[youtu.be] (extruder-idler close-up)
DSCF3437 by watsdesign, on Flickr
And a last video [www.flickr.com]
December 22, 2012 11:20AM
I'm trying to tune a little the acceleration settings.
From that thread there was some interesting but rare numbers.
Jamesdanielv
i use a setting between 20-35 for jerk settings. and 1 on the z axis setting. this is about right for my machine. any faster print quality suffers, and i have parts start to loosen up. you do want this as high as possible because prints will take less time. there are a lot of short moves in a print job. this setting effects the short moves. acceleration kicks in afterwards.
I think default settings are around 15. currently I have set my latest printer a prusa to 25 for x,y and 1 for z.
Sublime
For Tantillus I have the Acceleration set to 10000 for E and the Jerk set to 100 because of the need for a 5.5mm retract on the Bowden cable and we want it instantaneous. This may not work for most printers since on a bowden machine the filament springiness is enough to accelerate the extruder backwards really fast and prevent skipped steps while retracting.
So I raised a little my settings :
#define DEFAULT_RETRACT_ACCELERATION 5000 (was 3000)
#define DEFAULT_XYJERK 25.0 (was 20)
And the speed retract in Slic3r from 15 to 20mm/s
Will try with that numbers and a few other things smiling smiley
December 23, 2012 07:53PM
As expected it's way faster now tongue sticking out smiley
printing : [www.youtube.com]
another extruder close-up (to compare with the previous) : [www.youtube.com]
December 24, 2012 06:26AM
A new try :
#define DEFAULT_MAX_FEEDRATE {500, 500, 5, 50} (E was 45)
#define DEFAULT_MAX_ACCELERATION {9000,9000,50,10000} (E was 5000)
#define DEFAULT_RETRACT_ACCELERATION 10000 (was 5000)
#define DEFAULT_XYJERK 24.0 // (mm/sec) (was 25)
[/code]
And the travel speed in Slic3r from 200 to 500 mm/s, and retract speed from 20 to 25 mm/s
Will need more test for the print speeds, but the travel seems better (less resonance) smiling smiley
Edited 1 time(s). Last edit at 12/24/2012 10:47AM by Emmanuel.
January 15, 2013 03:14AM
Hello Emmanuel,
On my first prototype of MARepRap, the retraction parameter in Slic3r is 30 mm/s and this works fine. I think you could go from 20 to 30 mm/s.
Anyway, very good topic, I'm goind to improve my prototype parameters. smiling smiley
Edited 1 time(s). Last edit at 01/15/2013 08:43AM by pyroboynroses.
January 15, 2013 08:38AM
good to know smiling smiley
January 25, 2013 05:03AM
Some more videos of printing at 75-500mm/s grinning smiley
[youtu.be]
[youtu.be]
[youtu.be]
[youtu.be]
[youtu.be]
[youtu.be]
[youtu.be]
[youtu.be]
January 25, 2013 08:46AM
500mm/s is for the non printing moves, right ?
January 25, 2013 09:08AM
Yup !
January 25, 2013 03:43PM
How solid is this design? I was going to use the PG35L in the one I'm building right now.
January 28, 2013 04:49AM
I will finish to use use the PG35L I have, but I plan to use nema14 for the next machines. Especially since the geared motors are out of stock winking smiley
January 28, 2013 04:52AM
Yes, NEMA14 are easier to source.
