I tried the wooz J-Head mount for my foldarap - there's a space constraint that prevents it from working with the E3D all metal hotend, so I did my own - this makes provision for an M5 Nut to be used to retain the standard pneumatic fittings that foldarap uses, however it would be trivial to remove the top and use the larger tube that E3D supplies with their hotend (ask and ye shall receive - bear in mind that you'll need to adapt the extruder as the E3D bowden tube will not fit the M5 pneumatic fitting)
Download from thingiverse:
www.thingiverse.com]
Edited 1 time(s). Last edit at 04/09/2014 05:47PM by majic79.
