My First Experience with ABS: I Have a Problem June 17, 2014 08:02PM |
Re: My First Experience with ABS: I Have a Problem June 18, 2014 04:37AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: My First Experience with ABS: I Have a Problem June 18, 2014 05:30AM |
Re: My First Experience with ABS: I Have a Problem June 18, 2014 11:13AM |
Re: My First Experience with ABS: I Have a Problem June 18, 2014 01:08PM |
nophead
Kapton does stick too well for me. When I used Kapton I developed removable flexible beds that I could take off and bend. See [hydraraptor.blogspot.co.uk] and [hydraraptor.blogspot.co.uk].
nophead
I switched the PET tape because it is easier to remove the parts. Also Kapton's grip seems to fade over time whereas PET's doesn't.
Re: My First Experience with ABS: I Have a Problem June 18, 2014 01:14PM |
nophead
To remove parts stuck like that I take the glass off, hold it on its edge, put a block of wood on the top edge of the part and hit it with a hammer!
nophead
One thing to bear in mind is if you calibrate your Z axis for PLA it will be a bit low for ABS because the hot end expands more due to the higher temperature. If your first layer is low it will stick a lot harder.
