Error:Line Number is not Last Line Number+1, Last Line May 11, 2013 03:16PM |
Recv: T:239.94 E:0 B:125.0 Recv: ok Send: M105 Recv: Error:Line Number is not Last Line Number+1, Last Line:5 Recv: Resend:6 Recv: ok Send: M105 Recv: ok Send: M105 Recv: ok Send: M105 Recv: ok T:249.6 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:249.6 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:249.6 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:249.6 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:249.6 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:249.6 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:249.6 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:248.8 /240.0 B:125.0 /125.0 @:0% Send: M105 Recv: ok T:248.8 /240.0 B:125.0 /125.0 @:0% Send: M105 Recv: ok T:248.8 /240.0 B:125.0 /125.0 @:0% Send: M105 Recv: ok T:248.8 /240.0 B:125.0 /125.0 @:0% Send: M105 Recv: ok T:248.8 /240.0 B:125.0 /125.0 @:0% Send: M105 Recv: ok T:248.8 /240.0 B:125.0 /125.0 @:0% Send: M105 Recv: ok T:248.8 /240.0 B:125.0 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.1 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: M105 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: N6G1 X100Y100F9000*96 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: N7G1 Z0.05*110 Recv: ok T:250.3 /240.0 B:125.2 /125.0 @:0% Send: N8M109 S240*70 Recv: ok T:249.1 /240.0 B:125.0 /125.0 @:0% Send: N9G90*57 Recv: Printer stopped due to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
Re: Error:Line Number is not Last Line Number+1, Last Line May 11, 2013 04:29PM |
Recv: T:203.51 E:0 B:117.0 Recv: T:223.70 E:0 B:117.0 Recv: T:214.84 E:0 B:117.1 Recv: T:189.66 E:0 B:117.1 Recv: T:185.53 E:0 B:117.2 Recv: T:229.84 E:0 B:117.3 Recv: T:232.06 E:0 B:117.4 Recv: T:232.18 E:0 B:117.4 Recv: T:228.99 E:0 B:117.4 Recv: T:234.29 E:0 B:117.5 Recv: T:236.28 E:0 B:117.5 Recv: T:233.00 E:0 B:117.5 Recv: T:231.82 E:0 B:117.6 Recv: T:235.38 E:0 B:117.6 Recv: T:229.26 E:0 B:117.7 Recv: T:229.68 E:0 B:117.7 Recv: T:232.82 E:0 B:117.8 Recv: T:231.59 E:0 B:117.9 Recv: Error:0 Recv: : Extruder switched off. MINTEMP triggered ! Changing monitoring state from 'Printing' to 'Error: 0: Extruder switched...' Recv: Errorrinter stopped due to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting) Recv: ok Recv: Error:Line Number is not Last Line Number+1, Last Line:6 Recv: Resend:7 Recv: ok Changing monitoring state from 'Error: 0: Extruder switched...' to 'Closed' Changing monitoring state from 'Offline' to 'Opening serial port' Connecting to: /dev/ttyUSB0 Connected to: Serial(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor Changing monitoring state from 'Opening serial port' to 'Connecting' Connection closed, closing down monitor Send: M105 Recv: ok T:0.0 /0.0 B:112.9 /0.0 @:0% Changing monitoring state from 'Connecting' to 'Operational' Send: M105 Recv: ok T:0.0 /0.0 B:112.0 /0.0 @:0% Send: M105 Recv: ok T:0.0 /0.0 B:111.0 /0.0 @:0% Send: M105 Recv: ok T:0.0 /0.0 B:110.
Re: Error:Line Number is not Last Line Number+1, Last Line May 11, 2013 06:25PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 04:41AM |
SENDING:M105 ok T:234.6 /240.0 B:73.9 /130.0 @:0% SENDING:M105 ok T:234.6 /240.0 B:73.9 /130.0 @:0% SENDING:M105 ok T:241.4 /240.0 B:78.0 /130.0 @:24% Extruding 5.000000mm of filament. Printer stopped due to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 04:54AM |
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 05:31AM |
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 06:21AM |
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 09:40AM |
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 11:54AM |
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 12:01PM |
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 01:47PM |
ok T:16.6 /0.0 B:15.9 /0.0 @:0% Printer is now online. Setting hotend temperature to 240.000000 degrees Celsius. Error:0 : Extruder switched off. MINTEMP triggered ! Errorrinter stopped due to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 03:53PM |
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 04:17PM |
Connecting... ok T:13.0 /0.0 B:16.2 /0.0 @:0% Printer is now online. Setting hotend temperature to 240.000000 degrees Celsius. Extruding 5.000000mm of filament. Printer stopped due to errors. Fix the error and use M999 to restart!. (Temperature is reset. Set it before restarting)
Re: Error:Line Number is not Last Line Number+1, Last Line May 12, 2013 05:34PM |
Re: Error:Line Number is not Last Line Number+1, Last Line May 13, 2013 11:49AM |
Re: Error:Line Number is not Last Line Number+1, Last Line July 06, 2015 07:11PM |
