Mendel90 Dibond with GT2 Pulleys/belt May 23, 2013 02:22AM |
Re: Mendel90 Dibond with GT2 Pulleys/belt May 23, 2013 04:28AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 01, 2013 06:59AM |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 01, 2013 07:45AM |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 01, 2013 08:13AM |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 01, 2013 08:34AM |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 01, 2013 10:00AM |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 01, 2013 12:15PM |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 01, 2013 12:42PM |
I didn't ask you about pulley_flange_thickness" ???? No !!!
I am french so If I ask you about the meaning of following items , it's because it is not "self axplanatory" for me
function pulley_flange_thickness(type) = type[9];
Re: Mendel90 Dibond with GT2 Pulleys/belt June 01, 2013 01:00PM |
> ???? No !!!
> Yes you did
> 1) No pulley_hub_dia is the diameter of the hub,
> which is 16mm on that page.
> 2) It is on the diagram but the picture of the
> pulley shows it much thinner.
> 3) No it is the Z coordinate of the grub screw.
> 4) The pulley relative to the axle.
> 5) The Y coordinate of the captive nut used on
> plastic pulleys.
Re: Mendel90 Dibond with GT2 Pulleys/belt June 01, 2013 03:12PM |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 03, 2013 05:48PM |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 04, 2013 02:53AM |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 04, 2013 04:40AM |
Re: Mendel90 Dibond with GT2 Pulleys/belt June 05, 2013 11:43AM |
nophead Wrote:
> Pulley offset is a vector used to place the pulley
> at the right place on the motor shafts.
Re: Mendel90 Dibond with GT2 Pulleys/belt June 05, 2013 12:35PM |
Re: Mendel90 Dibond with GT2 Pulleys/belt January 02, 2015 05:15PM |
Re: Mendel90 Dibond with GT2 Pulleys/belt January 02, 2015 06:08PM |
