object dimension inaccuracy September 09, 2013 06:44PM |
Re: object dimension inaccuracy September 09, 2013 09:52PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: object dimension inaccuracy September 10, 2013 11:25AM |
Re: object dimension inaccuracy September 10, 2013 02:55PM |
Re: object dimension inaccuracy September 17, 2013 06:51AM |
Re: object dimension inaccuracy September 25, 2013 02:20AM |
Re: object dimension inaccuracy September 25, 2013 02:30PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: object dimension inaccuracy September 27, 2013 02:22AM |
Re: object dimension inaccuracy September 27, 2013 01:34PM |
Re: object dimension inaccuracy September 28, 2013 05:20PM |
Re: object dimension inaccuracy December 06, 2013 04:17PM |
lua "Flow_rate.lua" " < FILE > " without the spaces around the word FILE (the forum removes the < FILE and > if the spaces are not thereto the post-process field in the firmware tab of Kisslicer. Then at the top of the script file you will see where the variables are set to adjust the flow rate of each extrusion type, default 100%.
Re: object dimension inaccuracy December 06, 2013 06:46PM |
Re: object dimension inaccuracy December 06, 2013 07:31PM |
; 'Wipe (and De-string)', 0.0 [feed mm/s], 25.0 [head mm/s] G1 E-4 F30000 G1 X54.83 Y59.68 E0 F1500 ; fan on M106 ; ; 'Perimeter', 0.3 [feed mm/s], 25.0 [head mm/s] G1 X63.46 Y63.23 E0 F9000
; 'Wipe (and De-string)', 0.0 [feed mm/s], 25.0 [head mm/s] G1 E-4 F30000 G1 X54.83 Y59.68 E0 F1500 ; fan on M106 ; ; Set perimeter flow rate. <--- This comment is new M221 S100 <--- This M code is new ; 'Perimeter', 0.3 [feed mm/s], 25.0 [head mm/s] G1 X63.46 Y63.23 E0 F9000
Re: object dimension inaccuracy December 06, 2013 11:00PM |
Re: object dimension inaccuracy December 07, 2013 03:41AM |
Re: object dimension inaccuracy December 07, 2013 02:38PM |
Re: object dimension inaccuracy December 07, 2013 02:55PM |
Re: object dimension inaccuracy December 08, 2013 01:25PM |
Re: object dimension inaccuracy May 12, 2014 10:08PM |
Re: object dimension inaccuracy May 13, 2014 02:34AM |
qwert75
ive just recently been able to get back into printing and i just remembered your post process, it works really well its brilliant.
i was wondering if you ever got it working with slicer?
