So I made a quick "heated chamber" with some styrofoam insulation boards just to see if it would help print strength (it definitely did) and quickly found that it's too difficult to keep the air temperature constant. I'd rather not have to add a separate circuit for temperature control, so would moving the bed thermistor to a place near the print bed, but not on, work? The bed would then just be used as a space heater and the thermistor would measure air temperature (I would lower it of course from typical bed temps). I don't know much about PID, but I'm worried if there's too much distance between the bed and the thermistor, it might push the bed temperature too high. Any thoughts?
