Plans for Mendel90 to use 1.75mm filament? December 11, 2013 05:10AM |
Re: Plans for Mendel90 to use 1.75mm filament? December 11, 2013 05:48AM |
Re: Plans for Mendel90 to use 1.75mm filament? December 11, 2013 08:28AM |
Re: Plans for Mendel90 to use 1.75mm filament? December 11, 2013 08:53AM |
Re: Plans for Mendel90 to use 1.75mm filament? December 11, 2013 10:55AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Plans for Mendel90 to use 1.75mm filament? December 11, 2013 12:27PM |
Re: Plans for Mendel90 to use 1.75mm filament? December 11, 2013 12:33PM |
Re: Plans for Mendel90 to use 1.75mm filament? December 16, 2013 08:07PM |
Re: Plans for Mendel90 to use 1.75mm filament? December 22, 2013 11:55PM |
netsrac
Hi, the subject says it all...
Are there any plans to upgrade the Mendel90 to use 1.75mm filament? From what I've heard, it's the only way to get finer prints and details...
Thanks, Netsrac
Re: Plans for Mendel90 to use 1.75mm filament? December 28, 2013 09:57PM |
Re: Plans for Mendel90 to use 1.75mm filament? December 31, 2013 02:00PM |
goopyplastic
I have an option for 1.75mm on a mendel90 using the Ezstruder here:
[www.thingiverse.com]
Re: Plans for Mendel90 to use 1.75mm filament? January 02, 2014 05:47PM |
Garry Bartsch
Your designs look very nice. I would like to try this option. I'm wondering what changes I need to make to the M90 firmware to use the EZStruder? Also, the EZStruder works with 3mm or 1.75mm filament. Do you have experience with both sizes? Does it work equally well with both? Thanks a lot. Garry
Re: Plans for Mendel90 to use 1.75mm filament? January 06, 2014 03:28PM |
lions3
Garry Bartsch
technically it works with 3mm but I don't think the standard stepper motor has enough power to drive it. That's why everyone uses the a geared system like Wades for 3mm.
Re: Plans for Mendel90 to use 1.75mm filament? January 13, 2014 10:54AM |
Garry Bartsch
Then I will try to convert a J-Head to 1.75mm as Mogal describes above. So far the closest PTFE tube I can find on eBay is 3mm O.D. and 2mm I.D. Would this be the correct size to use?
Re: Plans for Mendel90 to use 1.75mm filament? January 14, 2014 04:50PM |
Re: Plans for Mendel90 to use 1.75mm filament? January 14, 2014 05:39PM |
lions3
Garry Bartsch
check the Jhead website. He normally sells the different PTFE liner sizes. [www.hotends.com]
Re: Plans for Mendel90 to use 1.75mm filament? January 14, 2014 07:56PM |
goopyplastic
I would imagine the main reason that makerbot is using 1.75mm is that direct drive extruders aren't strong enough for 3mm. On a bot where the extruder moves in both X and Y the weight / size of the extruder is important so 1.75 is important.
Re: Plans for Mendel90 to use 1.75mm filament? January 16, 2014 02:48PM |
Garry Bartsch
goopyplastic
Hi Goopyplastic,
I received the EZStruder I ordered and it looks very nice. I'm wondering what alterations you made to the firmware to make it work with your M90? Did you make any other changes to software related aspects of the M90? I have seen your extruder mounting solution on Thingiverse and it looks very nice.
Thank you and best regards,
Garry
Re: Plans for Mendel90 to use 1.75mm filament? January 16, 2014 07:58PM |
Re: Plans for Mendel90 to use 1.75mm filament? March 11, 2014 01:51PM |
Re: Plans for Mendel90 to use 1.75mm filament? March 26, 2014 04:27PM |
