Ideas for cleaning-up my corners January 13, 2014 05:26AM |
Re: Ideas for cleaning-up my corners January 13, 2014 12:51PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Ideas for cleaning-up my corners January 13, 2014 01:46PM |
nophead
Try halving the speed as that will quarter the kinetic energy dissipated by the oscillation. But I think the energy in an oscillation is proportional to the square of the amplitude, so you might still only reduce its amplitude by a factor of two.
nophead
You could also try the effect of halving the acceleration and or setting jerk to 0.
nophead
It would be interesting to see what happens if you rotate the bricks by 45 degrees.
Re: Ideas for cleaning-up my corners January 13, 2014 06:12PM |
Re: Ideas for cleaning-up my corners January 14, 2014 05:04AM |
Material: Reprapsource.com 4043D White PLA Layer height: 0.1mm Line width: 0.5mm (infill), 0.5mm (perimeter) Print speeds: 50mm/s (infill), 25mm/s (perimeter) Retraction: 1.0mm at 25mm/s Temperature: 185C (extruder), 80C first layer then 70C (heated bed) Print bed: 2mm float glass cleaned with Pure White Vinegar Clean-ups: None Special settings: M201 X1000 Y1000 (print acceleration), M205 X0 (XYJerk)Regards,
Re: Ideas for cleaning-up my corners January 14, 2014 05:25AM |
Re: Ideas for cleaning-up my corners January 14, 2014 06:06AM |
QuackingPlums
Wow, they look really good. Do they fit on actual Lego bricks?
