PSU Wiring Help January 17, 2014 09:30AM |
Re: PSU Wiring Help January 17, 2014 10:49AM |
Re: PSU Wiring Help January 17, 2014 11:44AM |
Re: PSU Wiring Help January 17, 2014 12:59PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: PSU Wiring Help January 17, 2014 01:10PM |
Re: PSU Wiring Help January 17, 2014 07:55PM |
Re: PSU Wiring Help January 18, 2014 04:46AM |
Re: PSU Wiring Help January 18, 2014 05:11AM |
Re: PSU Wiring Help January 18, 2014 09:22AM |
Re: PSU Wiring Help January 18, 2014 11:24AM |
Re: PSU Wiring Help January 30, 2014 02:39AM |
Re: PSU Wiring Help January 30, 2014 07:30AM |
Re: PSU Wiring Help January 30, 2014 08:45AM |
Re: PSU Wiring Help January 30, 2014 11:32AM |
Re: PSU Wiring Help January 31, 2014 08:13AM |
Re: PSU Wiring Help January 31, 2014 09:53AM |
It really depends on the design of the supply. Some work fine. Some don't. It can be hard on the supply though as the rails may be regulated separately.Quote
Jerms.a320
Is it alright to use a combination of 12v - 1 and 12v - 2 lines together ? - my power supply is/was modular (I got it free from a friend) and I have only 5 full length 12v 1 wires
Re: PSU Wiring Help January 31, 2014 10:30AM |
Re: PSU Wiring Help January 31, 2014 10:55AM |
Re: PSU Wiring Help January 31, 2014 01:53PM |
I'd just split them, one rail to one set of inputs, the other rail to the other set of inputs. I wouldn't get too caught up in the number of wires for each rail.Quote
Jerms.a320
On my PSU there are only 4 wires coming off the second "rail", and 8 from the first rail
I am using RAMPS 1.4 , I had a crack at measuring the resistance between the rails and got 0.00 Ohms
- should I just use 6 wires to the two inputs on the RAMPS board ?
Some power supplies require a load on the 3.3v and/or 5v rail in order to properly regulate the 12v. Your supply may or may not need this, but it's not going to hurt if it does not.Quote
I was just wondering why the green wire and the black are connected via the 4R7 resistor to the sense and orange wire, I haven't seen any people on youtube do that (I know its not that great a source ) ?
Re: PSU Wiring Help January 31, 2014 02:45PM |
Re: PSU Wiring Help January 31, 2014 06:38PM |
Re: PSU Wiring Help February 01, 2014 05:16AM |
Re: PSU Wiring Help February 01, 2014 07:28AM |
