Need parts for extruder connection PCB assembly May 10, 2014 10:44PM |
Re: Need parts for extruder connection PCB assembly May 11, 2014 02:52AM |
Re: Need parts for extruder connection PCB assembly May 11, 2014 06:05PM |
Re: Need parts for extruder connection PCB assembly May 12, 2014 10:14AM |
The problem is that the connector's pins won't line up with a standard .1" protoboard that all the header pins will want. So unless you're making a custom circuitboard, it's really not that much easier.Quote
isolt
It'd be a lot easier if you could find a PCB mount D plug though.
Re: Need parts for extruder connection PCB assembly January 01, 2018 01:22PM |
