Re: New E3D-V6 hotend - with10% off..... June 01, 2014 12:24PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: New E3D-V6 hotend - with10% off..... June 01, 2014 02:46PM |
Those changes in PID values have almost zero significance. It might be the difference between the hotend temperature varying by 2 degrees or 1.9 .Quote
Traveltrousers
After following the instructions, namely mount the head, run PID auto-tune and then mount the fan I can't print at 250 degrees... it seems the mini fan being on permanently keeps lowing the temperature and resetting the M109 command... should the fan be on all the time? Also, shouldn't I run PID with filament in the nozzle, surely this will effect the result...
I'm running PID again now with the fan and ABS inside, will report back...
Re: New E3D-V6 hotend - with10% off..... June 01, 2014 05:37PM |
Re: New E3D-V6 hotend - with10% off..... June 01, 2014 05:44PM |
Re: New E3D-V6 hotend - with10% off..... June 06, 2014 08:26AM |
