scale model of a mendel90 anyone? June 24, 2014 11:31AM |
Re: scale model of a mendel90 anyone? June 24, 2014 03:47PM |
Re: scale model of a mendel90 anyone? June 30, 2014 04:12AM |
Re: scale model of a mendel90 anyone? June 30, 2014 02:00PM |
Re: scale model of a mendel90 anyone? July 01, 2014 05:08PM |
Re: scale model of a mendel90 anyone? July 07, 2014 05:13PM |
Re: scale model of a mendel90 anyone? July 08, 2014 02:01AM |
Re: scale model of a mendel90 anyone? July 08, 2014 04:57AM |
Re: scale model of a mendel90 anyone? July 08, 2014 05:41AM |
Re: scale model of a mendel90 anyone? July 08, 2014 06:43AM |
Alzibiff
Looking good and this may be a minor point but I noticed that you have the post-print bed cooling fan protector cover on the wrong side of the dibond sheet. (Although as you do not have the fan installed, this may be deliberate).
The four screws pass through a plain washer, the fan guard, the left stay, the fan (if fitted) and finally a nyloc nut. There isn't a washer behind the fan because fan frames tend not to have room for one.I took this to read that the fan guard is fitted inside the machine to protect fingers roaming around the bed while the fan is active. Why would you want the guard outside?
Re: scale model of a mendel90 anyone? July 08, 2014 07:46AM |
neildarlow
I have my fan guard installed like this also. Reading the build manual:The four screws pass through a plain washer, the fan guard, the left stay, the fan (if fitted) and finally a nyloc nut. There isn't a washer behind the fan because fan frames tend not to have room for one.I took this to read that the fan guard is fitted inside the machine to protect fingers roaming around the bed while the fan is active. Why would you want the guard outside?
Re: scale model of a mendel90 anyone? July 08, 2014 08:18AM |
Alzibiff
The manual, as quoted is consistent with the fan guard on the outside. From the head of the screw (on the outside of the machine), the parts listed are in order: plain washer, fan guard, left stay, fan and then nut. If you start with the head of the screw on the inside, then surely the order gets muddled and would be, plain washer, fan guard, fan, left stay and then nut
Re: scale model of a mendel90 anyone? July 08, 2014 08:42AM |
Re: scale model of a mendel90 anyone? July 08, 2014 10:05AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: scale model of a mendel90 anyone? July 08, 2014 11:42AM |
nophead
The guard goes on the outside of the machine and the fan, if fitted, goes on the inside blowing towards the bed. I don't see any ambiguity if the instructions are read while consulting the assembly diagram.
Re: scale model of a mendel90 anyone? July 08, 2014 12:45PM |
Re: scale model of a mendel90 anyone? July 08, 2014 03:55PM |
Re: scale model of a mendel90 anyone? July 08, 2014 06:39PM |
nophead
Yes I think it will cool faster on the inside and the only purpose of the fan is to speed things up.
Re: scale model of a mendel90 anyone? July 08, 2014 07:31PM |
Re: scale model of a mendel90 anyone? July 09, 2014 01:46AM |
Re: scale model of a mendel90 anyone? July 09, 2014 04:22AM |
Re: scale model of a mendel90 anyone? July 09, 2014 07:19AM |
Re: scale model of a mendel90 anyone? July 09, 2014 10:40AM |
Re: scale model of a mendel90 anyone? July 10, 2014 05:23AM |
QuackingPlums
I hope you're saving all the modified design files for us so that we can print our own once you've done all the hard work!
Re: scale model of a mendel90 anyone? July 10, 2014 05:55AM |
Re: scale model of a mendel90 anyone? July 16, 2014 02:52AM |
Re: scale model of a mendel90 anyone? July 17, 2014 08:30AM |
Re: scale model of a mendel90 anyone? July 17, 2014 09:23AM |
QuackingPlums
Are you still looking for a model of the Melzi board? I just knocked this one up quickly from the dimensions specified in the RepRap wiki and positioned all the components by eye (I'm not by my printer so I can't measure it directly) - is it good enough for a model?
Re: scale model of a mendel90 anyone? July 17, 2014 09:54AM |
Re: scale model of a mendel90 anyone? July 20, 2014 09:44AM |
