There are CMOS logic-level-compatible MOSFETS that feature a built-in flywheel diode between Drain and Source.
These can be driven directly without the need for a series resistor although a pull-down resistor is advised to ensure the MOSFET is disabled until the microprocessor output is configured to drive a logic low level after reset.
Your Melzi should have a 10-way (2x5) pin header just above the USB connector (labelled JP16 on the circuit diagram). Pin 6 or pin 8 of this connector is usually used to drive the Bed Fan via the MOSFET.
Pin 8 of the 15-way D-type connector is not connected to the ribbon cable.
The two pins marked PP are intended for a Z Probe. One is connected to the thermistor ground. The other is currently unused and appears as a spare wire at the Melzi-end of the ribbon cable.
Regards,
Neil Darlow
Edited 1 time(s). Last edit at 07/07/2014 06:17AM by neildarlow.
I try to write with consideration for all nationalities. Please let me know if something is unclear.
Printing with Mendel90 from fedora 25 using Cura, FreeCAD, MeshLab, OpenSCAD, Skeinforge and Slic3r tools.
