On my Mendel90 based printer design-in-progress I have the end stop switch operating positions set at 102.5mm for X and 102.6mm for Y. To make sure I am explaining it properly, I mean that when the X carriage moves 102.5mm left from the point when the nozzle is dead center on the print bed it will trigger the X end stop switch. And similarly, when the Y carriage moves 102.6mm forward from the point when the nozzle is dead center on the print bed it will trigger the Y end stop switch. Phew, sorry for that ...
Firstly, I want to know how to tell Marlin the operating position of the end stops. Is it '// Travel limits after homing' in configuration.h?
#define X_MIN_POS -100
#define X_MAX_POS 100
#define Y_MIN_POS -100
#define Y_MAX_POS 100
And if so, in my case I would do this?:
#define X_MAX_POS 102.5
#define Y_MAX_POS 102.6
Second, if the above is on the right track, should I be setting the end stop operating position exactly 100mm from the nozzle dead center point rather than my 102.5mm and 102.6mm? I can easily alter my design but I thought having a we bit of spare room on the limits would be a good idea??
Thanks in advance for any advice.
