Raspberry PI vs. Panelolu2 for stand-alone use? September 29, 2014 09:00PM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? September 30, 2014 03:27AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 01, 2014 06:04PM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 01, 2014 06:34PM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 02, 2014 02:10AM |
Rich K.
Okay, so is there a good, cheap, and easy to set up system that will allow me to run my printer 100% independently ( not counting using a seperate computer for slicing and burning g-code on SD cards), without needing wi-fi or Bluetooth capability or
access?
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 02, 2014 04:30AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 02, 2014 04:44AM |
Rich K.
So in other words, I would not be able to use Nophead's fork for Marlin with that setup?
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 02, 2014 04:45AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 02, 2014 07:36PM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 03, 2014 02:34AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 03, 2014 02:38AM |
Rich K.
Now, can I use that particular firmware upgrade with my laptop, BEFORE I get a P2 or a R-PI? Or should I stick with Nophead's version until I am ready to upgrade the system?
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 03, 2014 04:24AM |
Sorry, but what exactly is PID? I will be using 3mm borosilicate glass to cover the bed, BTW.Quote
neildarlow
If you want to use the Heated Bed PID temperature control feature it has to be enabled manually because it is necessary to run a PID Auto-tune cycle. I was not going to make assumptions about what type of glass people print on so you need to determine the PID constants yourself.
Regards,
Neil Darlow
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 03, 2014 09:59AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 03, 2014 09:38PM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 04, 2014 06:22AM |
Rich K.
What add-ons will I need to get along with the basic R-PI to use it with the Melzi and P2?
Also, can I power the R-PI from the same power suppply as the Melzi and P2? I'm using a 600 watt ATX power supply.
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 04, 2014 05:52PM |
Alzibiff
A USB cable to connect the RPi to the MELZI. You will also need some way of connecting the Pi to your home network - either an ethernet cable if you are going to hard wire it or a USB WiFi dongle.
Alan
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 04, 2014 06:58PM |
Rich K.
I was actually looking to run the printer without having to connect to my home network - the idea being to make the printer more transportable and useable in case I want to take it somewhere WITHOUT wi-fi or other networking, and don't want to tie up my only "full-featured" computer.
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 04, 2014 07:25PM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 06, 2014 09:11PM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 13, 2014 05:58PM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 14, 2014 04:03AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 14, 2014 04:12AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 14, 2014 04:28AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 14, 2014 04:37AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 14, 2014 04:49AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 14, 2014 04:54AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 17, 2014 10:46PM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 18, 2014 09:57AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 18, 2014 10:25AM |
Re: Raspberry PI vs. Panelolu2 for stand-alone use? October 18, 2014 11:49AM |
