Print Stops Midway Through October 10, 2014 08:16PM |
Re: Print Stops Midway Through October 11, 2014 02:37AM |
Garry Bartsch
.... It seems to be obviously between the computer and printer somehow....
Re: Print Stops Midway Through October 11, 2014 06:41AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Print Stops Midway Through October 11, 2014 03:38PM |
Alzibiff
Not necessarily. It might be worth eliminating the USB connection entirely by printing directly from the SD card for a while.
Re: Print Stops Midway Through October 11, 2014 04:19PM |
nophead
Check the ground connection to the melzi is tight.
nophead
The problem is completely solved if you use octoprint on a raspberry pi that is powered from the the same PSU and grounded to the Melzi.
