Interpreting a test print October 26, 2014 04:17PM |
Re: Interpreting a test print October 26, 2014 05:08PM |
Re: Interpreting a test print October 26, 2014 05:32PM |
Re: Interpreting a test print October 26, 2014 05:49PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Interpreting a test print October 26, 2014 06:08PM |
Re: Interpreting a test print October 26, 2014 08:11PM |
Re: Interpreting a test print October 30, 2014 06:22PM |
Re: Interpreting a test print October 31, 2014 07:19AM |
Re: Interpreting a test print October 31, 2014 07:33AM |
Re: Interpreting a test print October 31, 2014 07:46AM |
Re: Interpreting a test print October 31, 2014 10:00AM |
The value of Z_HOME_POS largely depends on where you set the X-carriage height before you start the bed levelling procedure. I place the temporary washers under the front bed pillars and measure the bed height there before adjusting the Z-screws to a similar height. This has given me a Z_HOME_POS of 203.92 after final skirt measurement.
If you set the Z-screws too high before levelling you find that you have to raise the front of the bed significantly by adjusting the pillars. I try to minimise the amount of adjustment needed there.
Re: Interpreting a test print October 31, 2014 10:04AM |
Re: Interpreting a test print October 31, 2014 12:44PM |
Re: Interpreting a test print October 31, 2014 02:51PM |
Re: Interpreting a test print October 31, 2014 05:51PM |
Re: Interpreting a test print October 31, 2014 06:25PM |
Re: Interpreting a test print October 31, 2014 06:45PM |
nophead
Sorry Neil, I don't understand what you are saying here. The bed should be levelled before Z_HOME_POS is calibrated. After that it is determined by the nozzle length, exact position of the top Z bracket, etc. It doesn't depend on where the X carriage was when you levelled the bed. The back two pillars should always be tight against the washers, only the front two are adjusted to get it level front to back.
Re: Interpreting a test print November 01, 2014 05:40AM |
Re: Interpreting a test print November 01, 2014 06:34AM |
nophead
In practice some iteration is needed but I don't see any dependency on the initial position of the Z screws.
Re: Interpreting a test print November 01, 2014 06:49AM |
Re: Interpreting a test print November 01, 2014 09:24AM |
Re: Interpreting a test print November 01, 2014 09:32AM |
Re: Interpreting a test print November 01, 2014 01:10PM |
Re: Interpreting a test print November 01, 2014 04:09PM |
Re: Interpreting a test print November 01, 2014 07:10PM |
Re: Interpreting a test print November 02, 2014 07:14AM |
Re: Interpreting a test print November 02, 2014 07:17AM |
