Z axis problem
Posted by paulnd
Z axis problem
November 04, 2014 03:16AM
Hello,
I'll be grateful for any assistance with my recently built Mendel90.
I can move the Z axis using the Pronterface controls and G0 without any problems and it also homes correctly. However as soon as the print starts only one of the Z axis motors turns. I've tried adjusting the trim pot on the Ramps 1.4 driver without effect and I'm using a 500W PSU.
Regards
Paul
Re: Z axis problem
November 04, 2014 06:02AM
Could be that you have the max speed set higher in the firmware than the jog speed you are using in pronterface. Could also be the 12V rail dropping when the bed is on. Have you got dummy loads attached to 5V and 3.3V rails?
Re: Z axis problem
November 04, 2014 08:02AM
I'll check the max speed when I'm at home tonight but I have tried setting it lower. Load resistors are connected to both rails
Re: Z axis problem
November 04, 2014 10:05AM
Also try turning the bed and extruder on in pronterface and see if you can still jog it in both directions.
I can't think of anything else that can be different between jogging it and printing other than speed or power supply load.
Edited 1 time(s). Last edit at 11/04/2014 10:06AM by nophead.
Re: Z axis problem
November 04, 2014 05:12PM
I reduced the feed rate to 3mm/sec which seems to have solved the problem. Thanks for your help.
