The order of construction is the same but nearly all the fasteners are different, belts and cables, etc are slightly different lengths. Each section starts with a bill of materials. Accurate versions of those can be found in the sturdy/bom folder.
Printed cable clips are used instead of zip ties. The wires run on top of the base, rather than underneath it. There is no need for aluminium bars underneath as there are no nuts underneath because wood screws are used.
www.hydraraptor.blogspot.com]
