J-Head: Delay of Extrustion after Cleaning - Hot End broken?
January 21, 2015 03:24PM
Hallo everybody,
I currently have a Problem with my Mendel90 from nophead after having really problems after printing Laywood. Let me tell the story:
Due to the fact that my girlfriend wants to have name signs made of Laywood D3 for our upcoming wedding, I gave Laywood a try. Before that I only printed with Faberdashery and only had the common problems one coud have in a cold cellar. (Warping on the side facing the door, etc).
I printed the signs at 180-240 degrees and made the terrible mistake to wait for the extruder to reach the temperature. After several failed prints I gave up and tried to flush the whole hotend with the original supplied green PLA. I don't know what went wrong, if I was too slow, if I used a too high temperature,... nevertheless the PLA got stuck in the COLD end! That's why I had to pull the J-Head apart and remove the stuck PLA with the help of a hot copper wire i stuck in the PLA and a cup of hot water. After the removal I put the whole thing together, cleaned the hobbed bold and inserted PLA filament again.
Now here is the problem: When I heat up the PLA to lets say 185C and extrude it, it comes out with no problems. But if I try to print, the first view layers with 3mm height looks more like a 0.05mm height and an infill more like a field of tiny little dots. About the second or third layer all gets to the normal state , maybe even more filament is coming out then normal. I tried to flush the whole system again, but couldn't improve it. Suprisingly the retracted filament does not have the normal shape of a dot, it is more like a long long string, sometimes with dots.
That's why I am thinking I ruined my hotend. Is there any way to fix it?
(I ordered some drills with 0.3mm diameter but they didn't arrive yet and that's why I cant say that poking may be an option)
I really woud appriciate your help
Regards
Christoph
Re: J-Head: Delay of Extrustion after Cleaning - Hot End broken?
January 21, 2015 03:47PM
If the first layer is too thin it looks like your Z calibration is out after replacing the hot end. Maybe it isn't pushed as far into the Wade's block, so it is a bit lower. Seems like it is actually pressed hard against the glass and is effectively blocking the nozzle.
Note this can cause overpressure that causes the hot end to leak.
January 21, 2015 05:12PM
thx for the very fast reply - this really would mean I just have to play around with the z height in the config file. Thank you for your help
Really good news winking smiley
I keep you all informed
January 22, 2015 03:52PM
Update: the Z Height was really the problem. Thanks for your help nophead!
