Printing the bearing holders February 05, 2015 09:25AM |
Re: Printing the bearing holders February 05, 2015 12:08PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Printing the bearing holders February 05, 2015 01:26PM |
I've noticed my hotend briefly overshoots by 2 or 3 degrees when first heating up to printing temperature, hence keeping my max at 242 (measured from the thermistor) should keep me a couple of degrees below the specified limit at all times. If you measure inside the nozzle, how much offset do you see between that and the thermistor temperature?Quote
Please note: The maximum operating temperature is 247 degrees Celsius as PEEK will soften at 248 degrees Celsius. Due to many variables, affecting the accuracy of the temperature readings and settings, caution is recommended when extruding at temperatures approaching this limit.
Re: Printing the bearing holders February 05, 2015 01:41PM |
Re: Printing the bearing holders February 05, 2015 01:54PM |
