e3dv6 help
March 13, 2016 11:01AM
hi all
first post so bear with me lol
i brought a fully working mendel90 all setup and ready to go (which means i have no idea how to fix it )
i have been using it for a year with no problems at all
then i got my first nozzle jam so i got a e3dv6
i have kinda got it screwed in with the 3 washers at a 45 degree angle (I'm hoping this will do till i can print out another with more depth to the hole it sits in or print a bowden is it indirect extruder)
i have got to wire the hottend fan to be on all the time
i need to change the thermistor settings some where
and change the nozzle height somewhere i assume
i think thats it although I'm not really sure
i have searched the net and this forum for a guide but could not find something i can follow
any help at all would be greatly appreciated
thankyou
Re: e3dv6 help
March 13, 2016 04:32PM
- manual: [github.com]
- mine sits flush without the screws at an angle, i had to use a ball head hex wrench. This should be a firm fit
- permanent ground and 12v can be found off of the melzi connectors: [github.com]
- this is in configuration.h and will need a firmware rebuild
- again, this is in configuration.h
Re: e3dv6 help
March 13, 2016 09:39PM
the e3dv6 hot end needs more depth to fit flush
if i try to drill it and mess it up i won't be able to print another
thanks for the reply i will carry on trying
Edited 1 time(s). Last edit at 03/13/2016 09:46PM by phil-notts.
Re: e3dv6 help
March 14, 2016 04:05AM
No E3D V6 needs less depth than a J Head Mk5B, not more. The normal solution is to put an M8 washer under it to pack it pack it out. You must have something else.
Re: e3dv6 help
March 14, 2016 09:08AM
i got it direct from e3d
i rang them up to ask them which one would fit
this is what they sent
[/img]
Re: e3dv6 help
March 14, 2016 11:13AM
I think you must have the Bowden version instead of the direct version. It should look like this: [e3d-online.com]
Re: e3dv6 help
March 14, 2016 11:39AM
i see the top part that is 7mm on mine is thinner on the other one
Re: e3dv6 help
March 14, 2016 01:13PM
as far as i am aware e3d-v6 only has a blue fan duct, i have never seen one with a red duct.
Re: e3dv6 help
March 14, 2016 01:23PM
hophead is right its a bowden version
the question is can i get it all working to print myself the parts to make the bits i need
Re: e3dv6 help
March 14, 2016 07:51PM
alkempster
E3D mounts red fan duct on V6 Lite version.
