Frames...accuracy and/or upgrade??? April 14, 2016 05:47PM |
Re: Frames...accuracy and/or upgrade??? April 15, 2016 03:24AM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Frames...accuracy and/or upgrade??? April 20, 2016 03:39PM |
nophead
but you need a CNC to make that version.
Re: Frames...accuracy and/or upgrade??? April 20, 2016 04:57PM |
Re: Frames...accuracy and/or upgrade??? April 21, 2016 12:57PM |
Re: Frames...accuracy and/or upgrade??? April 21, 2016 01:49PM |
nophead
...designed to be cut with a CNC I took advantage of that and made some of the holes slots and rounded the corners.
For cutting Dibond with a router you want a single spiral fluted endmill... ...I don't know if a Dremel is up the the job. I use an 800W Kress spindle motor.
danielis
I built mine with 3mm Dibond with my simple home tools and all went and is still fine.
Only thing is the sheets should be cut square by a circular saw or something where you have the sheets really square.
I ordered mine here: [www.electronic-things.de]
Hopefully you can find a shop where you can order them cut to size. The rest can be done by hand without special tools.
Re: Frames...accuracy and/or upgrade??? May 03, 2016 05:44AM |
Re: Frames...accuracy and/or upgrade??? May 03, 2016 09:12AM |
Re: Frames...accuracy and/or upgrade??? October 08, 2016 01:29PM |
