d-sub connector library? October 29, 2015 09:43AM |
Re: d-sub connector library? October 29, 2015 10:27AM |
Re: d-sub connector library? October 29, 2015 12:38PM |
Re: d-sub connector library? October 29, 2015 03:56PM |
Re: d-sub connector library? October 30, 2015 04:04AM |
b = db_conn_table(conn)[0]; d = db_conn_table(conn)[1]; f = db_conn_table(conn)[2]; k = db_conn_table(conn)[3];
b = conn_dimensions[0]; d = conn_dimensions[1]; f = conn_dimensions[2]; k = conn_dimensions[3];
conn_dimensions = db_conn_table(conn);
Re: d-sub connector library? October 30, 2015 04:23AM |
// dsub.scad
// D-Sub connector library by 'dpeart'
function db_conn_table(idx) =
// [b,d,f,k]
idx == "db9F" ? [12.50,11.10,6.53,2.11] :
idx == "db9R" ? [12.50,11.10,5.72,3.35] :
idx == "db15F" ? [16.66,15.27,6.53,2.11] :
idx == "db15R" ? [16.66,15.27,5.72,3.35] :
idx == "db25F" ? [23.52,22.15,6.53,2.11] :
idx == "db25R" ? [23.52,21.39,5.72,3.35] :
idx == "db37F" ? [31.75,29.54,6.53,2.11] :
idx == "db37R" ? [31.75,29.54,5.72,3.35] :
idx == "db50F" ? [30.56,29.19,7.93,2.11] :
idx == "db50R" ? [30.56,28.17,7.06,3.35] :
"Error";
//dsub("db25R");
module dsub(conn)
if(conn_dimensions == "Error")
echo(str("ERROR: Connector '", conn, "' not found"));
echo("ERROR: Allowed are db9F, db9R, db15F, db15R, db25F, db25R, db37F, db37R, db50F and db50R.");
color("red")
for ( a = [-45,45])
rotate([0,0,a])
cube([4,20,4], true);
else
cut_angle = 10;
mounting_hole = 3.05;
sides = 20;
translate([0,0,-0.5])
union()
hull()
//Upper Left
translate([-(d-k),(f-k),0])
cylinder(h=1, d=k, $fn=sides);
//Upper Right
translate([(d-k),(f-k),0])
//Lower Left
translate([-(d-k)+cos(cut_angle),-(f-k),0])
//Lower Right
translate([(d-k)-cos(cut_angle),-(f-k),0])
// Mounting Holes
translate([-b,0,0])
cylinder(h=1, d=mounting_hole, $fn=6);
translate([b,0,0])
use <dsub.scad>
dsub("db25R");
Re: d-sub connector library? October 30, 2015 08:11AM |
Re: d-sub connector library? October 30, 2015 03:53PM |
Re: d-sub connector library? November 02, 2015 04:46AM |
// dsub.scad
// [b,d,f,k]
"Error";
//dsub("db25R");
module dsub(conn)
sides = 20;
color("red")
for ( a = [-45,45])
rotate([0,0,a])
else
cut_angle = 10;
o = 2*(f-k) * tan(cut_angle);
union()
hull()
//Upper Left
//Upper Right
//Lower Left
translate([-(d-k)+o,-(f-k),0])
//Lower Right
translate([(d-k)-o,-(f-k),0])
// Mounting Holes
translate([-b,0,0])
translate([b,0,0])
Re: d-sub connector library? November 03, 2015 06:18AM |
// dsub.scad
// [b,d,f,k]
"Error";
//dsub("db9R");
//dsub("db25R",0.2);
module dsub(conn, g=0)
sides = 20;
color("red")
for ( a = [-45,45])
rotate([0,0,a])
else
cut_angle = 10;
o = 2*(g+f-k)*tan(cut_angle);
union()
hull()
//Upper Left
translate([-(g+d-k),(g+f-k),0])
//Upper Right
translate([(g+d-k),(g+f-k),0])
//Lower Left
translate([-(g+d-k)+o,-(g+f-k),0])
//Lower Right
translate([(g+d-k)-o,-(g+f-k),0])
// Mounting Holes
translate([-b,0,0])
cylinder(h=1, d=g+mounting_hole, $fn=6);
translate([b,0,0])
Re: d-sub connector library? November 04, 2015 11:46AM |
Re: d-sub connector library? November 04, 2015 04:27PM |
Re: d-sub connector library? November 04, 2015 04:31PM |
