Is openscad being maintained/improved? May 15, 2017 12:21PM |
Re: Is openscad being maintained/improved? May 16, 2017 01:07AM |
Re: Is openscad being maintained/improved? May 16, 2017 11:41AM |
Re: Is openscad being maintained/improved? May 19, 2017 12:46AM |
Re: Is openscad being maintained/improved? May 19, 2017 07:22AM |
Re: Is openscad being maintained/improved? May 22, 2017 07:48PM |
Re: Is openscad being maintained/improved? May 28, 2017 11:58PM |
wingmaster
It is possible to save the design as step file using freecad.
Install openscad as plugin in freecad. open your .scad design in freecad and then export as step file. Works great.
Re: Is openscad being maintained/improved? May 28, 2017 11:59PM |
dmould
I absolutely agree about having more export options. I often design parts for injection moulding and would love to be able to use OpenScad to do so, but unfortunately the company that does the tooling does not accept STL files (which is 100% understandable because STL files do not contain accurate curves).
You could write a module to implement the function of bending over a positioned axle.
Dave
