[upravy draftu]Re: Skeinforge manuál v ČJ [upravy draftu] September 20, 2013 10:00AM |
Re: Skeinforge manuál v ČJ September 20, 2013 12:39PM |
Re: Skeinforge manuál v ČJ September 20, 2013 01:15PM |
M113 S1.0 M104 S60.0 (*layer* 0.72 ) M104 S200.0 (*skirt*)
M113 S1.0 M104 S200.0 (*layer* 0.72 ) (*skirt*)
M190 S*setting.chamber.BedTemperature* dosadi hodnotu nastavenou v Chamber -> BedTemperature
Re: Skeinforge manuál v ČJ September 20, 2013 02:16PM |
Re: Skeinforge manuál v ČJ September 20, 2013 04:38PM |
Re: Skeinforge manuál v ČJ September 21, 2013 02:54AM |
Re: Skeinforge manuál v ČJ September 21, 2013 05:25AM |
Re: Skeinforge manuál v ČJ September 21, 2013 07:26AM |
Re: Skeinforge manuál v ČJ September 21, 2013 11:10AM |
Re: Skeinforge manuál v ČJ September 21, 2013 04:18PM |
Re: Skeinforge manuál v ČJ September 22, 2013 06:15AM |
Re: Skeinforge manuál v ČJ September 22, 2013 09:12AM |
Re: Skeinforge manuál v ČJ September 22, 2013 10:45AM |
Re: Skeinforge manuál v ČJ September 22, 2013 12:10PM |
Re: Skeinforge manuál v ČJ September 22, 2013 01:59PM |
test.04hx06w_03fill_33EL.gcode znamena: - . (z carve - XXhxXXw). : 04h = 0,4mm - tloustka vrstvy v mm 06w = 0.6 sirka neboly 0.4 x Perimeter Width over Thickness (ratio): 1.5 - (z Fill - _XXfill): 03fill = 0.3 (Infill solidity (ratio)) - (z Multiply - _XXcxXXr): - nebude pouzit, pokud je nastaven 1 radek a 1 sloupce (1 tisk modelu) 2c = pocet sloupcu x 2r = pocer radku - (z Speed) 33EL = Feed Rate (mm/s) = 33.0 a Flow Rate Setting (float) = 33. pokud kterakoliv z hodnot bude mit desetinou cast, bude take zde zobrazena, pokud bude 0, bude hodnota skryta. pokud se hodnoty budou lisit (nemely by s 5D objemovou metodou), bude kazda zobrazena samostatne (napr. 35.2E30L = 'Feed Rate (mm/s):' 35.2 a 'Flow Rate Setting (float):' 30.0)
Re: Skeinforge manuál v ČJ September 22, 2013 02:22PM |
Re: Skeinforge manuál v ČJ September 22, 2013 03:44PM |
Re: Skeinforge manuál v ČJ September 22, 2013 06:00PM |
Re: Skeinforge manuál v ČJ September 23, 2013 01:55AM |
Re: Skeinforge manuál v ČJ September 23, 2013 04:15PM |
Re: Skeinforge manuál v ČJ September 23, 2013 03:23PM |
Re: Skeinforge manuál v ČJ September 23, 2013 04:17PM |
Re: Skeinforge manuál v ČJ September 24, 2013 01:19AM |
Re: Skeinforge manuál v ČJ September 24, 2013 04:16AM |
rez valcem: na vysku: nepozna - pozna - 000000 000000 000000000000 000 000 000 000 0000 0000 000 000 0000 0000 000 000 000 000 0000 0000 000000 000000 0000 0000
Re: Skeinforge manuál v ČJ September 24, 2013 04:45AM |
Re: Skeinforge manuál v ČJ September 24, 2013 05:18AM |
Re: Skeinforge manuál v ČJ September 24, 2013 03:43PM |
Re: Skeinforge manuál v ČJ September 24, 2013 03:22PM |
Re: Skeinforge manuál v ČJ September 25, 2013 01:24PM |
Re: Skeinforge manuál v ČJ September 25, 2013 01:31PM |
