Filament vyjíždí z extruderu
Posted by paycz
December 05, 2015 03:04PM
Ahoj, tiskárna již plně funguje až na extrůder který vrací zpět filament který vypadne
extruder MK8
nastavení firmware
* MOVEMENT SETTINGS
#define HOMING_FEEDRATE {50*60, 50*60, 4*60, 0} // set the homing speeds (mm/min)
// default settings
#define DEFAULT_AXIS_STEPS_PER_UNIT {6/1.1, 6, 227.5/1.15,93} // default steps per unit for Ultimaker
#define DEFAULT_MAX_FEEDRATE {300, 300, 0.5, 20} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {3000,3000,1,3000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 300 // X, Y, Z and E acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 300 // E acceleration in mm/s^2 for retracts
#define DEFAULT_TRAVEL_ACCELERATION 300 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves
// The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously)
#define DEFAULT_XYJERK 20.0 // (mm/sec)
#define DEFAULT_ZJERK 0.4 // (mm/sec)
#define DEFAULT_EJERK 5.0 // (mm/sec)
Re: Filament vyjíždí z extruderu
December 05, 2015 03:48PM
otoč konektor od motoru extruderu
December 05, 2015 03:53PM
nejsem tak hloupej při tisku teče filament z hotendu ale po pár vrstvách filament vyjede
dan
December 06, 2015 04:23AM
Promin, ale to ze nejsi "tak hloupej" se neda z uvodniho postu poznat.
Pokud ti to tedy nejak aspon chvilku tiskne, tak bych asi hledal chybu ve vygenerovanem g-codu a ne v nastaveni FW. To "vypadnuti" je vzdy na stejnem miste/pri steje vrstve ?
Asi mas FW Marlin, ten nepouzivam, takze ho zmaklej moc nemam, ale nezda se mi definice kroku/mm pro osy XYZ
Jake mas prevody/drivery a jejich nastaveni? Nebo pouzivas EEPROM a tyhle parametry to ignoruje.
Edited 1 time(s). Last edit at 12/06/2015 04:25AM by dan.
_______________
Rebel ? winking smiley
[rebelove.org]
December 06, 2015 07:10AM
co presne myslis tim, ze vypadne???
udela opacnej pohyb, jako ze najednou vyjede zpet o treba 2 cm?
nebo se ve skutecnosti priucpe, filament se tlaci dal, drat se prerve a vyjede jinudy?
udela pohyb zpet asi se prilepy na hotend (chladnou cast), davkovani pokracuje, ale tim se prerve a vyjede jinudy??? (nedojde k prodreni filamentu)
muze to bejt nakej bug firmwaru, ale spis bych to videl na neco se slicovacem
jakej slicovaci program pouzivas?
od nake verze cury se treba nedaj kloudne nastavit retrakce (nebo sem to nenasel tam, kde to bylo v predchozi verzi a pak uz sem to nehledal), takze udela asi 4cm retrakt a pokud mas extruder, kterej nema dost prostoru, filament vyjede mimo podavaci sroub, nebo misto zavedeni do extruderu a pak vyjede jinudy.
pripadne poslat foto problemu???
vlastni navrh plus ve vystavbe CoreXY
Thingiverse : [www.thingiverse.com]
git: [github.com]
shop: [shop.daje.cz]
Teorie relativity:
vysvetleni 1: sahnes-li na rozpalenou panev, vteriny jsou jak hodiny. sahnes-li na rozpalenou zenu, hodiny jsou jak vteriny...
vysvetleni 2: strcis-li mi nos do zadnice, pak ja mam nos v zadku, ty mas nos v zadku, ale ja sem na tom relativne lip smiling smiley
December 06, 2015 09:09AM
dneska jsem sledoval tisk a filament se nejspíše ucvaknul a lezl bokem jak to mám opravit ?
dan
December 06, 2015 10:54AM
sem posli nejakou fotku. nenapsal si ani co mas za tiskarnu, nikdo tu netusi, jak mas udelany extruder, jak mohlo dojit k ucvaknuti, lezeni bokem a co chces vlastne opravovat.
_______________
[rebelove.org]
December 06, 2015 01:24PM
extruder MK8
tiskárna prusa i3
open | download - 12358531_196018970740738_456174286_n.jpg (62.2 KB)
December 06, 2015 01:29PM
pri pohledu na foto - typoval bych to na problemy s chlazenim - takze bud jinej hotend, nebo pridat mezi heatblok a extruder jeste chaldic
vypada to ze tam neni ani neco jako heatbreak na ty spojovaci casti heatblok - extruder
pravdepodobne se tam nekde prilepi plast, nebo utvori zatka v chladnejsi casti hotendu a nasleduje ono vyjeti mimo, jak nemuze tlacit drat dal do diry extruderu
paycz
extruder MK8
tiskárna prusa i3
Edited 1 time(s). Last edit at 12/06/2015 01:30PM by raptik.
git: [github.com]
Teorie relativity:
December 06, 2015 01:49PM
dodál jsem tam vetráček z pc akorát teď místo posouvání filamentu motor jen tak klepe
December 06, 2015 02:34PM
raptik ti pisal ze chyba heat break!
medzi heatblokom (hlinikova kocka s vyhrievacim telieskom) a chladicom (zlta hlinikova konstrukcia extrudera) nesmie byt ta matka co tam mas ale na tej zavitovej trubke musi byt zuzena cast bez zavitu aby sa teplo z trysky dostaalo co najpomalsie a co najmenej smerom hore.
takto nejak to ma vyzerat (ta zuzena cast bez zavitu je heat break):
[www.cool3dprinter.com]
