Re: Höhe des Druckbett justieren 31. October 2015 14:27 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.448 |
Re: Höhe des Druckbett justieren 31. October 2015 15:40 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 2.094 |
/* Experimental motorized bed leveling (G33 command) for printers with three individual motors for the z axis (print bed).
You do need a working Z probe (FEATURE_Z_PROBE) and three individual steppers (FEATURE_TWO_ZSTEPPER and FEATURE_THREE_ZSTEPPER)
for this feature to work.
This feature does NOT work and is not necessary for delta printers as there is no motorized bed.
#define FEATURE_MOTORIZED_LEVELING 1
#define MOTORIZED_LEVELING_REPETITIONS 3 // Repetitions of leveling for increased precision
#define MOTORIZED_LEVELING_ITERATIONS 5 // max. number of leveling iterations per leveling repetition
#define MOTORIZED_LEVELING_MAX_ERROR 0.1f // max. error allowed (in millimeters) when leveling z axis
/* Z1 motor driver is the reference point for motorized bed leveling. Z2_DRIVER and Z3_DRIVER are the other stepper drivers.
The order of the steppers is important as it does have a effect on the levling precision. As the steppers are aligned as a
triangle you should level them in the following order:
3
1---2
#define Z1_DRIVER(var) StepperDriver var(ZAXIS_STEPS_PER_MM,MAX_FEEDRATE_Z/2)
#define Z2_DRIVER(var) StepperDriver var(ZAXIS_STEPS_PER_MM,MAX_FEEDRATE_Z/2)
#define Z3_DRIVER(var) StepperDriver var(ZAXIS_STEPS_PER_MM,MAX_FEEDRATE_Z/2)
Re: Höhe des Druckbett justieren 31. October 2015 16:07 |
Re: Höhe des Druckbett justieren 31. October 2015 16:23 |
Re: Höhe des Druckbett justieren 31. October 2015 17:48 |
Re: Höhe des Druckbett justieren 31. October 2015 20:57 |
Re: Höhe des Druckbett justieren 01. November 2015 04:11 |
Re: Höhe des Druckbett justieren 01. November 2015 06:23 |
12:10:41.574 : Info:Autoleveling disabled 12:10:41.578 : Info:Motorized bed leveling repetition 1 12:10:41.582 : Info:leveling z1 and z2, iteration 1 12:10:49.795 : Z-probe:5.09 X:40.00 Y:20.00 12:10:58.974 : Z-probe:4.13 X:240.00 Y:20.00 12:11:08.350 : Z-probe:5.02 X:145.00 Y:240.00 12:11:13.119 : Transformation matrix: 0.999989 0.000009 0.004770 0.000000 0.999998 -0.001970 -0.004770 0.001970 0.999987 12:11:13.123 : Info:adjusting z2 by 2.36mm 12:11:13.123 : Info:leveling z1 and z2, iteration 2 12:11:19.590 : Z-probe:5.07 X:40.00 Y:20.00 12:11:28.753 : Z-probe:4.13 X:240.00 Y:20.00 12:11:32.186 : Transformation matrix: 0.999989 0.000010 0.004747 0.000000 0.999998 -0.002008 -0.004747 0.002008 0.999987 12:11:32.186 : Info:adjusting z2 by 2.34mm 12:11:32.190 : Info:leveling z1 and z2, iteration 3 12:11:37.928 : Z-probe:5.08 X:40.00 Y:20.00 12:11:47.099 : Z-probe:4.13 X:240.00 Y:20.00 12:11:50.536 : Transformation matrix: 0.999989 0.000009 0.004748 0.000000 0.999998 -0.001988 -0.004748 0.001988 0.999987 12:11:50.536 : Info:adjusting z2 by 2.35mm 12:11:50.540 : Info:leveling z1 and z2, iteration 4 12:11:56.283 : Z-probe:5.08 X:40.00 Y:20.00 12:12:05.467 : Z-probe:4.14 X:240.00 Y:20.00 12:12:08.908 : Transformation matrix: 0.999989 0.000009 0.004745 0.000000 0.999998 -0.001964 -0.004745 0.001964 0.999987 12:12:08.912 : Info:adjusting z2 by 2.34mm 12:12:08.912 : Info:leveling z1 and z2, iteration 5 12:12:14.650 : Z-probe:5.08 X:40.00 Y:20.00 12:12:23.814 : Z-probe:4.12 X:240.00 Y:20.00 12:12:27.242 : Transformation matrix: 0.999989 0.000010 0.004775 0.000000 0.999998 -0.002005 -0.004775 0.002005 0.999987 12:12:27.246 : Info:adjusting z2 by 2.36mm 12:12:27.250 : Info:leveling z1 and z2, iteration 6 12:12:32.985 : Z-probe:5.08 X:40.00 Y:20.00 12:12:42.152 : Z-probe:4.13 X:240.00 Y:20.00 12:12:45.585 : Transformation matrix: 0.999989 0.000010 0.004767 0.000000 0.999998 -0.002001 -0.004767 0.002001 0.999987 12:12:45.585 : Info:adjusting z2 by 2.35mm 12:12:45.589 : Info:leveling z3 to center of z1 and z2, iteration 1 12:12:51.323 : Z-probe:5.08 X:40.00 Y:20.00 12:13:00.486 : Z-probe:4.12 X:240.00 Y:20.00 12:13:09.846 : Z-probe:5.01 X:145.00 Y:240.00 12:13:14.610 : Transformation matrix: 0.999989 0.000010 0.004791 0.000000 0.999998 -0.001988 -0.004791 0.001988 0.999987 12:13:14.610 : Info:adjusting z3 by -0.67mm 12:13:14.614 : Info:leveling z3 to center of z1 and z2, iteration 2 12:13:21.077 : Z-probe:5.08 X:40.00 Y:20.00 12:13:30.236 : Z-probe:4.12 X:240.00 Y:20.00 12:13:39.588 : Z-probe:5.01 X:145.00 Y:240.00 12:13:44.348 : Transformation matrix: 0.999988 0.000010 0.004798 0.000000 0.999998 -0.001980 -0.004798 0.001980 0.999987 12:13:44.348 : Info:adjusting z3 by -0.66mm 12:13:44.352 : Info:leveling z3 to center of z1 and z2, iteration 3 12:13:50.815 : Z-probe:5.07 X:40.00 Y:20.00 12:13:59.974 : Z-probe:4.12 X:240.00 Y:20.00 12:14:09.329 : Z-probe:5.01 X:145.00 Y:240.00 12:14:14.090 : Transformation matrix: 0.999989 0.000009 0.004773 0.000000 0.999998 -0.001984 -0.004773 0.001984 0.999987 12:14:14.094 : Info:adjusting z3 by -0.66mm 12:14:14.098 : Info:leveling z3 to center of z1 and z2, iteration 4 12:14:20.557 : Z-probe:5.07 X:40.00 Y:20.00 12:14:29.716 : Z-probe:4.11 X:240.00 Y:20.00 12:14:39.063 : Z-probe:5.00 X:145.00 Y:240.00 12:14:42.136 : Printer reset detected - initalizing
Re: Höhe des Druckbett justieren 01. November 2015 06:43 |
#define Z1_DRIVER(var) StepperDriver{Z_STEP_PIN, Z_DIR_PIN, Z_ENABLE_PIN, INVERT_Z_DIR, Z_ENABLE_ON} var(ZAXIS_STEPS_PER_MM,MAX_FEEDRATE_Z/2)
#define Z2_DRIVER(var) StepperDriver{Z3_STEP_PIN, Z3_DIR_PIN, Z3_ENABLE_PIN, INVERT_Z_DIR, Z_ENABLE_ON} var(ZAXIS_STEPS_PER_MM,MAX_FEEDRATE_Z/2)
#define Z3_DRIVER(var) StepperDriver{Z2_STEP_PIN, Z2_DIR_PIN, Z2_ENABLE_PIN, INVERT_Z_DIR, Z_ENABLE_ON} var(ZAXIS_STEPS_PER_MM,MAX_FEEDRATE_Z/2)
Re: Höhe des Druckbett justieren 01. November 2015 07:05 |
13:02:23.613 : X:290.00 Y:0.00 Z:0.000 E:0.0000 13:02:27.268 : X:290.00 Y:290.00 Z:0.000 E:0.0000 13:02:36.492 : Info:Motorized bed leveling repetition 1 13:02:36.496 : Info:leveling z1 and z2, iteration 1 13:02:44.340 : Z-probe:5.62 X:40.00 Y:20.00 13:02:54.593 : Z-probe:4.67 X:240.00 Y:20.00 13:03:05.108 : Z-probe:5.56 X:145.00 Y:240.00 13:03:10.420 : Transformation matrix: 0.999989 0.000009 0.004759 0.000000 0.999998 -0.001986 -0.004759 0.001986 0.999987 13:03:10.420 : Info:adjusting z2 by 2.35mm 13:03:10.424 : Info:leveling z1 and z2, iteration 2 13:03:17.445 : Z-probe:5.62 X:40.00 Y:20.00 13:03:27.702 : Z-probe:4.67 X:240.00 Y:20.00 13:03:31.683 : Transformation matrix: 0.999989 0.000009 0.004762 0.000000 0.999998 -0.001978 -0.004762 0.001978 0.999987 13:03:31.683 : Info:adjusting z2 by 2.35mm 13:03:31.687 : Info:leveling z1 and z2, iteration 3 13:03:38.053 : Z-probe:5.63 X:40.00 Y:20.00 13:03:48.338 : Z-probe:4.67 X:240.00 Y:20.00 13:03:52.320 : Transformation matrix: 0.999989 0.000009 0.004781 0.000000 0.999998 -0.001961 -0.004781 0.001961 0.999987 13:03:52.320 : Info:adjusting z2 by 2.36mm 13:03:52.324 : Info:leveling z1 and z2, iteration 4 13:03:53.221 : Printer reset detected - initalizing
Re: Höhe des Druckbett justieren 01. November 2015 07:17 |
Re: Höhe des Druckbett justieren 01. November 2015 07:50 |
Re: Höhe des Druckbett justieren 01. November 2015 11:52 |
Re: Höhe des Druckbett justieren 01. November 2015 12:02 |
Re: Höhe des Druckbett justieren 02. November 2015 06:32 |
z2Motor.setCurrentAs(0); z2Motor.gotoPosition(hDiff);
MAX_FEEDRATE_Z/4mal auf /4 wie zuvor verändert, ob es daran liegt, aber nix.
z2Motor.gotoPosition(hdiff)anstatt hdiff einen anderen (festen) Wert eintrage, geschieht nix.
Re: Höhe des Druckbett justieren 02. November 2015 06:41 |
Re: Höhe des Druckbett justieren 02. November 2015 07:46 |
13:43:00.864 : X:0.00 Y:290.00 Z:0.000 E:0.0000 13:43:04.666 : X:290.00 Y:290.00 Z:0.000 E:0.0000 13:43:08.307 : Info:Motorized bed leveling repetition 1 13:43:08.311 : Info:leveling z1 and z2, iteration 1 13:43:17.789 : Z-probe:5.84 X:40.00 Y:20.00 13:43:31.360 : Z-probe:7.11 X:240.00 Y:20.00 13:43:44.459 : Z-probe:4.97 X:145.00 Y:240.00 13:43:49.379 : Transformation matrix: 0.999980 0.000045 -0.006362 0.000000 0.999975 0.006998 0.006362 -0.006998 0.999955 13:43:49.383 : Info:adjusting z2 by -3.14mm 13:43:49.387 : Info:leveling z1 and z2, iteration 2 13:43:57.587 : Z-probe:5.77 X:40.00 Y:20.00 13:44:11.051 : Z-probe:7.07 X:240.00 Y:20.00 13:44:17.433 : Transformation matrix: 0.999979 0.000044 -0.006540 0.000000 0.999977 0.006745 0.006540 -0.006745 0.999956 13:44:17.433 : Info:adjusting z2 by -3.23mm 13:44:17.437 : Info:leveling z1 and z2, iteration 3 13:44:24.609 : Z-probe:5.76 X:40.00 Y:20.00 13:44:38.167 : Z-probe:7.07 X:240.00 Y:20.00 13:44:44.545 : Transformation matrix: 0.999979 0.000044 -0.006553 0.000000 0.999977 0.006733 0.006553 -0.006732 0.999956 13:44:44.550 : Info:adjusting z2 by -3.24mm 13:44:44.550 : Info:leveling z1 and z2, iteration 4 13:44:51.632 : Z-probe:5.76 X:40.00 Y:20.00 13:45:05.198 : Z-probe:7.07 X:240.00 Y:20.00 13:45:10.118 : Printer reset detected - initalizing
14:06:43.644 : Info:Motorized bed leveling repetition 1 14:06:43.644 : Info:leveling z1 and z2, iteration 1 14:06:56.764 : Z-probe:8.86 X:40.00 Y:20.00 14:07:16.392 : Z-probe:10.15 X:240.00 Y:20.00 14:07:35.775 : Z-probe:8.13 X:145.00 Y:240.00 14:07:43.857 : Transformation matrix: 0.999979 0.000041 -0.006434 0.000000 0.999980 0.006383 0.006434 -0.006383 0.999959 14:07:43.862 : Info:adjusting z2 by -3.18mm 14:07:43.865 : Info:leveling z1 and z2, iteration 2 14:07:55.072 : Z-probe:8.82 X:40.00 Y:20.00 14:08:14.632 : Z-probe:10.12 X:240.00 Y:20.00 14:08:24.064 : Transformation matrix: 0.999979 0.000041 -0.006542 0.000000 0.999981 0.006230 0.006542 -0.006230 0.999959 14:08:24.064 : Info:adjusting z2 by -3.23mm 14:08:24.068 : Info:leveling z1 and z2, iteration 3 14:08:34.203 : Z-probe:8.82 X:40.00 Y:20.00 14:08:53.766 : Z-probe:10.13 X:240.00 Y:20.00 14:09:01.016 : Printer reset detected - initalizing
Re: Höhe des Druckbett justieren 02. November 2015 07:49 |
13:47:02.610 : Info:Motorized bed leveling repetition 1 13:47:02.614 : Info:leveling z1 and z2, iteration 1 13:47:10.614 : Z-probe:4.36 X:40.00 Y:20.00 13:47:21.321 : Z-probe:5.73 X:240.00 Y:20.00 13:47:34.920 : Z-probe:6.86 X:145.00 Y:240.00 13:47:41.728 : Transformation matrix: 0.999977 -0.000055 -0.006834 0.000000 0.999967 -0.008080 0.006834 0.008080 0.999944 13:47:41.732 : Info:adjusting z2 by -3.38mm 13:47:41.736 : Info:leveling z1 and z2, iteration 2 13:47:48.506 : Z-probe:4.38 X:40.00 Y:20.00 13:47:59.345 : Z-probe:5.71 X:240.00 Y:20.00 13:48:04.367 : Transformation matrix: 0.999978 -0.000054 -0.006684 0.000000 0.999967 -0.008078 0.006684 0.008078 0.999945 13:48:04.367 : Info:adjusting z2 by -3.30mm 13:48:04.371 : Info:leveling z1 and z2, iteration 3 13:48:10.077 : Z-probe:4.38 X:40.00 Y:20.00 13:48:20.805 : Z-probe:5.73 X:240.00 Y:20.00 13:48:25.839 : Transformation matrix: 0.999977 -0.000054 -0.006704 0.000000 0.999968 -0.008040 0.006704 0.008040 0.999945 13:48:25.839 : Info:adjusting z2 by -3.31mm 13:48:25.843 : Info:leveling z1 and z2, iteration 4 13:48:26.896 : Printer reset detected - initalizing
13:51:21.022 : Info:Motorized bed leveling repetition 1 13:51:21.026 : Info:leveling z1 and z2, iteration 1 13:51:27.757 : Z-probe:3.01 X:40.00 Y:20.00 13:51:35.768 : Z-probe:4.35 X:240.00 Y:20.00 13:51:43.453 : Z-probe:2.32 X:145.00 Y:240.00 13:51:45.734 : Transformation matrix: 0.999977 0.000042 -0.006718 0.000000 0.999980 0.006307 0.006718 -0.006307 0.999958 13:51:45.739 : Info:adjusting z2 by -3.32mm 13:51:45.742 : Info:leveling z1 and z2, iteration 2 13:51:51.125 : Z-probe:2.99 X:40.00 Y:20.00 13:51:59.035 : Z-probe:4.30 X:240.00 Y:20.00 13:52:02.648 : Transformation matrix: 0.999978 0.000041 -0.006575 0.000000 0.999981 0.006162 0.006575 -0.006162 0.999959 13:52:02.648 : Info:adjusting z2 by -3.25mm 13:52:02.652 : Info:leveling z1 and z2, iteration 3 13:52:06.993 : Z-probe:2.99 X:40.00 Y:20.00 13:52:14.907 : Z-probe:4.30 X:240.00 Y:20.00 13:52:18.516 : Transformation matrix: 0.999979 0.000040 -0.006540 0.000000 0.999981 0.006168 0.006540 -0.006168 0.999960 13:52:18.520 : Info:adjusting z2 by -3.23mm 13:52:18.520 : Info:leveling z1 and z2, iteration 4 13:52:20.634 : Printer reset detected - initalizing
Re: Höhe des Druckbett justieren 02. November 2015 08:14 |
Re: Höhe des Druckbett justieren 04. November 2015 11:08 |
17:05:53.406 : Info:Motorized bed leveling repetition 1 17:05:53.410 : Info:leveling z1 and z2, iteration 1 17:05:59.189 : Z-probe:1.91 X:38.00 Y:0.00 17:06:03.933 : Z-probe:1.89 X:270.00 Y:10.00 17:06:08.971 : Z-probe:1.91 X:145.00 Y:240.00 17:06:10.843 : Info:no more leveling necessary, bed is flat 17:06:10.847 : Info:motorized bed leveling completed succesfully
Re: Höhe des Druckbett justieren 05. November 2015 02:22 |
Re: Höhe des Druckbett justieren 07. November 2015 11:21 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 56 |
17:14:19.352 : Info:leveling z3 to center of z1 and z2, iteration 1 17:14:25.218 : Z-probe:5.24 X:0.00 Y:60.00 17:14:32.711 : Z-probe:4.56 X:270.00 Y:60.00 17:14:39.712 : Z-probe:4.43 X:120.00 Y:300.00 17:14:41.235 : Transformation matrix: 0.999997 -0.000005 0.002522 0.000000 0.999998 0.002118 -0.002522 -0.002118 0.999995 17:14:41.235 : Info:adjusting z3 by 0.47mm 17:14:41.239 : Info:leveling z3 to center of z1 and z2, iteration 2 17:14:46.991 : Z-probe:5.25 X:0.00 Y:60.00 17:14:54.697 : Z-probe:4.57 X:270.00 Y:60.00 17:15:01.779 : Z-probe:4.43 X:120.00 Y:300.00 17:15:03.299 : Transformation matrix: 0.999997 -0.000005 0.002512 0.000000 0.999998 0.002150 -0.002512 -0.002150 0.999995 17:15:03.303 : Info:adjusting z3 by 0.48mm 17:15:03.307 : Info:leveling z3 to center of z1 and z2, iteration 3 17:15:09.080 : Z-probe:5.25 X:0.00 Y:60.00 17:15:16.584 : Z-probe:4.57 X:270.00 Y:60.00 17:15:23.668 : Z-probe:4.43 X:120.00 Y:300.00 17:15:25.188 : Transformation matrix: 0.999997 -0.000005 0.002526 0.000000 0.999998 0.002153 -0.002526 -0.002153 0.999994 17:15:25.192 : Info:adjusting z3 by 0.48mm 17:15:25.196 : Info:leveling z3 to center of z1 and z2, iteration 4 17:15:30.955 : Z-probe:5.25 X:0.00 Y:60.00 17:15:38.465 : Z-probe:4.57 X:270.00 Y:60.00 17:15:45.482 : Z-probe:4.43 X:120.00 Y:300.00 17:15:47.002 : Transformation matrix: 0.999997 -0.000005 0.002531 0.000000 0.999998 0.002148 -0.002531 -0.002148 0.999994 17:15:47.006 : Info:adjusting z3 by 0.48mm 17:15:47.010 : Info:leveling z3 to center of z1 and z2, iteration 5 17:15:52.761 : Z-probe:5.25 X:0.00 Y:60.00 17:16:00.455 : Z-probe:4.57 X:270.00 Y:60.00 17:16:07.541 : Z-probe:4.43 X:120.00 Y:300.00 17:16:09.061 : Transformation matrix: 0.999997 -0.000005 0.002552 0.000000 0.999998 0.002155 -0.002552 -0.002155 0.999994 17:16:09.065 : Info:adjusting z3 by 0.48mm 17:16:09.069 : Info:leveling z3 to center of z1 and z2, iteration 6 17:16:14.842 : Z-probe:5.26 X:0.00 Y:60.00 17:16:22.347 : Z-probe:4.57 X:270.00 Y:60.00 17:16:29.425 : Z-probe:4.43 X:120.00 Y:300.00 17:16:30.950 : Transformation matrix: 0.999997 -0.000006 0.002557 0.000000 0.999998 0.002168 -0.002557 -0.002168 0.999994 17:16:30.950 : Info:adjusting z3 by 0.48mm 17:16:30.954 : X:120.00 Y:300.00 Z:3.000 E:0.0000 17:16:30.958 : Info:motorized bed leveling completed succesfully
Glatzemann
Kopiere mal bitte den folgenden Code über die drei Zeilen mit deinen Motor-Defines:
#define Z1_DRIVER(var) StepperDriver{Z_STEP_PIN, Z_DIR_PIN, Z_ENABLE_PIN, INVERT_Z_DIR, Z_ENABLE_ON} var(ZAXIS_STEPS_PER_MM,MAX_FEEDRATE_Z/2) #define Z2_DRIVER(var) StepperDriver{Z3_STEP_PIN, Z3_DIR_PIN, Z3_ENABLE_PIN, INVERT_Z_DIR, Z_ENABLE_ON} var(ZAXIS_STEPS_PER_MM,MAX_FEEDRATE_Z/2) #define Z3_DRIVER(var) StepperDriver{Z2_STEP_PIN, Z2_DIR_PIN, Z2_ENABLE_PIN, INVERT_Z_DIR, Z_ENABLE_ON} var(ZAXIS_STEPS_PER_MM,MAX_FEEDRATE_Z/2)
Danach bitte { durch eine dreieckige Klammer auf (< ) ersetzen und } durch eine dreieckige Klammer zu (> ). Die Pinne sind darin etwas "verdreht" und der define für den ersten Motor ist anders.
16:55:38.419 : Info:leveling z3 to center of z1 and z2, iteration 4 16:55:42.671 : Z-probe:2.17 X:0.00 Y:60.00 16:55:47.230 : Z-probe:1.51 X:270.00 Y:60.00 16:55:51.397 : Z-probe:1.40 X:120.00 Y:300.00 16:55:51.434 : Transformation matrix: 0.999997 -0.000005 0.002472 0.000000 0.999998 0.001977 -0.002472 -0.001977 0.999995 16:55:51.434 : Info:adjusting z3 by 0.44mm 16:55:51.438 : Info:leveling z3 to center of z1 and z2, iteration 5 16:55:55.694 : Z-probe:2.18 X:0.00 Y:60.00 16:56:00.253 : Z-probe:1.50 X:270.00 Y:60.00 16:56:04.415 : Z-probe:1.40 X:120.00 Y:300.00 16:56:04.448 : Transformation matrix: 0.999997 -0.000005 0.002483 0.000000 0.999998 0.001970 -0.002483 -0.001970 0.999995 16:56:04.452 : Info:adjusting z3 by 0.44mm 16:56:04.456 : Info:leveling z3 to center of z1 and z2, iteration 6 16:56:08.713 : Z-probe:2.18 X:0.00 Y:60.00 16:56:13.272 : Z-probe:1.50 X:270.00 Y:60.00 16:56:17.434 : Z-probe:1.40 X:120.00 Y:300.00 16:56:17.471 : Transformation matrix: 0.999997 -0.000005 0.002517 0.000000 0.999998 0.001960 -0.002517 -0.001960 0.999995 16:56:17.475 : Info:adjusting z3 by 0.43mm 16:56:17.475 : X:120.00 Y:300.00 Z:1.437 E:0.0000 16:56:17.479 : Info:motorized bed leveling completed succesfully
Re: Höhe des Druckbett justieren 07. November 2015 13:19 |
Re: Höhe des Druckbett justieren 08. November 2015 04:20 |
Re: Höhe des Druckbett justieren 08. November 2015 05:26 |
Re: Höhe des Druckbett justieren 08. November 2015 05:37 |
Re: Höhe des Druckbett justieren 08. November 2015 05:52 |
Re: Höhe des Druckbett justieren 08. November 2015 06:08 |
Re: Höhe des Druckbett justieren 08. November 2015 06:51 |
Mav
Ich muss gleich erstmal meine Pflicht erfüllen und mit Freundin zum Verkaufsoffenen Sonntag in die Stadt
Re: Höhe des Druckbett justieren 08. November 2015 12:22 |
17:54:27.597 : Info:leveling z1 and z2, iteration 5 17:54:42.418 : Z-probe:14.99 X:0.00 Y:60.00 17:55:04.149 : Z-probe:15.22 X:270.00 Y:60.00 17:55:11.069 : Transformation matrix: 1.000000 0.000003 -0.000868 0.000000 0.999992 0.004031 0.000868 -0.004031 0.999991 17:55:11.079 : Info:adjusting z2 by -0.23mm 17:55:11.189 : Info:leveling z1 and z2, iteration 6 17:55:26.090 : Z-probe:14.99 X:0.00 Y:60.00 17:55:47.863 : Z-probe:15.22 X:270.00 Y:60.00 17:55:54.783 : Transformation matrix: 1.000000 0.000003 -0.000848 0.000000 0.999992 0.004016 0.000848 -0.004016 0.999991 17:55:54.793 : Info:adjusting z2 by -0.23mm 17:55:54.913 : Info:leveling z3 to center of z1 and z2, iteration 1 17:56:09.804 : Z-probe:14.99 X:0.00 Y:60.00 17:56:31.565 : Z-probe:15.22 X:270.00 Y:60.00 17:56:53.326 : Z-probe:13.82 X:120.00 Y:300.00 17:56:59.547 : Transformation matrix: 1.000000 0.000004 -0.000851 0.000000 0.999986 0.005277 0.000851 -0.005277 0.999986 17:56:59.557 : Info:adjusting z3 by 1.28mm 17:57:00.347 : Info:leveling z3 to center of z1 and z2, iteration 2 17:57:15.778 : Z-probe:15.34 X:0.00 Y:60.00 17:57:38.209 : Z-probe:16.24 X:270.00 Y:60.00 17:58:00.430 : Z-probe:14.07 X:120.00 Y:300.00 17:58:06.781 : Transformation matrix: 0.999995 0.000023 -0.003306 0.000000 0.999976 0.006963 0.003306 -0.006963 0.999970 17:58:06.781 : Info:adjusting z3 by 1.72mm 17:58:07.811 : Info:leveling z3 to center of z1 and z2, iteration 3 17:58:23.482 : Z-probe:15.81 X:0.00 Y:60.00 17:58:46.923 : Z-probe:17.59 X:270.00 Y:60.00 17:59:10.035 : Z-probe:14.39 X:120.00 Y:300.00 17:59:16.545 : Transformation matrix: 0.999978 0.000061 -0.006594 0.000000 0.999957 0.009229 0.006595 -0.009228 0.999936 17:59:16.545 : Info:adjusting z3 by 2.31mm 17:59:17.895 : Info:leveling z3 to center of z1 and z2, iteration 4 17:59:33.886 : Z-probe:16.45 X:0.00 Y:60.00 17:59:58.829 : Z-probe:19.99 X:270.00 Y:60.00 18:00:23.350 : Z-probe:14.83 X:120.00 Y:300.00 18:00:30.090 : Transformation matrix: 0.999914 0.000175 -0.013136 0.000000 0.999912 0.013290 0.013138 -0.013289 0.999825 18:00:30.090 : Info:adjusting z3 by 3.39mm 18:00:32.120 : Info:leveling z3 to center of z1 and z2, iteration 5 18:00:48.471 : Z-probe:17.35 X:0.00 Y:60.00 18:01:15.253 : Z-probe:22.95 X:270.00 Y:60.00 18:01:41.545 : Z-probe:15.48 X:120.00 Y:300.00 18:01:48.605 : Transformation matrix: 0.999785 0.000376 -0.020713 0.000000 0.999835 0.018161 0.020716 -0.018157 0.999621 18:01:48.605 : Info:adjusting z3 by 4.67mm 18:01:51.445 : Info:leveling z3 to center of z1 and z2, iteration 6 18:02:09.037 : Z-probe:19.70 X:0.00 Y:60.00 18:02:38.998 : Z-probe:26.97 X:270.00 Y:60.00
