Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 07:59 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.292 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 08:07 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 2.094 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 08:33 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 4.977 |
Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 08:56 |
/* Define the type of axis movements needed for your printer. The typical case is a full cartesian system where x, y and z moves are handled by separate motors. 0 = full cartesian system, xyz have seperate motors. 1 = z axis + xy H-gantry (x_motor = x+y, y_motor = x-y) 2 = z axis + xy H-gantry (x_motor = x+y, y_motor = y-x) 3 = Delta printers (Rostock, Kossel, RostockMax, Cerberus, etc) 4 = Tuga printer (Scott-Russell mechanism) 5 = Bipod system (not implemented) Cases 1 and 2 cover all needed xy H gantry systems. If you get results mirrored etc. you can swap motor connections for x and y. If a motor turns in the wrong direction change INVERT_X_DIR or INVERT_Y_DIR. */ #define DRIVE_SYSTEM 0 // ########################################################################################## // ## Calibration ## // ########################################################################################## /** Drive settings for the Delta printers */ #if DRIVE_SYSTEM==3 // *************************************************** // *** These parameter are only for Delta printers *** // *************************************************** /** \brief Delta drive type: 0 - belts and pulleys, 1 - filament drive */ #define DELTA_DRIVE_TYPE 0 #if DELTA_DRIVE_TYPE == 0 /** \brief Pitch in mm of drive belt. GT2 = 2mm */ #define BELT_PITCH 2 /** \brief Number of teeth on X, Y and Z tower pulleys */ #define PULLEY_TEETH 20 #define PULLEY_CIRCUMFERENCE (BELT_PITCH * PULLEY_TEETH) #elif DELTA_DRIVE_TYPE == 1 /** \brief Filament pulley diameter in milimeters */ #define PULLEY_DIAMETER 10 #define PULLEY_CIRCUMFERENCE (PULLEY_DIAMETER * 3.1415927) #endif
// Delta robot radius endstop #define max_software_endstop_r true
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 10:22 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 11:07 |
Registrierungsdatum: 9 Jahre zuvor Beiträge: 338 |
Hm, das halte ich für suboptimalQuote
Und da ich ja sowieso für den End-Anwender nur Binaries anbieten wollte ...
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 11:46 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 11:59 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 12:11 |
Da bin ich voll bei Dir.Quote
Ich fände es halt cool, wenn man mit bossac bzw. einer Funktion im Host-Programm die Firmware-Binary auf das Microcontroller-Board laden kann, ohne das eine Entwicklungsumgebung auf dem Rechner des Anwenders installiert sein muss.
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 12:17 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 12:43 |
Administrator Registrierungsdatum: 16 Jahre zuvor Beiträge: 13.890 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 13:28 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 14:11 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 14:45 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 14:49 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 18:39 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 06. November 2015 22:51 |
Lach - ich würde nicht mal im Traum auf so eine Idee kommen.Quote
Versuch mal z.B. Eclipse oder Visual Studio so zu konfigurieren, daß man auf ein MC-Board laden kann.
So sehr ich auch Respekt vor Deiner Arbeit habe, so suboptimal finde ich diesen Ansatz.Quote
Die Idee ist ja, daß du nur noch ein Binary für alle Geräte hast.
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 07. November 2015 05:14 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 495 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 07. November 2015 07:33 |
um sich Gedanken über Sicherheit zu machen, muss man kein Programmierer, sondern eher ein wenig paranoid seinQuote
ich bin ja keine Programmiererin
Hm, scheint irgendwie Mode zu sein, mich falsch zu interpretieren.Quote
Nichts gegen Unix oder Linux, aber wenn man erst eine Firmware mit einem "Make" compillieren lassen und dann auf den Controller übertragen lassen würde, würde man alle, die kein Wissen über Linux oder nur Linux-Anwender sind, doch überfordern und auch gleich die Win-Leute außen vor lassen.
Nur weil ich Arduino nicht mag, heißt das nicht, dass ich Marlin schlecht finden würde. Ganz im Gegenteil.Quote
Ich finde nicht, dass Marlin schlecht wäre
Es gibt unendlich viele Beispiele, wie man es nicht machen sollte.Quote
(Ich habe einen 20 Zoll Monitor und konnte in der IDE nicht alle Untermenüs der Firmware anwählen), dann, um bestimmte Dinge zu finden, muss man unendlich suchen.
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 16. January 2016 04:48 |
Registrierungsdatum: 12 Jahre zuvor Beiträge: 200 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 16. January 2016 08:16 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 56 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 17. January 2016 05:12 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 70 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 17. January 2016 06:13 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 18. January 2016 08:26 |
Registrierungsdatum: 11 Jahre zuvor Beiträge: 222 |
#define RED_BLUE_STATUS_LEDS 1
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 18. January 2016 08:29 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 18. January 2016 11:47 |
Registrierungsdatum: 8 Jahre zuvor Beiträge: 444 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 18. January 2016 14:38 |
Registrierungsdatum: 10 Jahre zuvor Beiträge: 1.164 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 19. January 2016 05:05 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 20. January 2016 06:48 |
Re: ThirtyTwo - Eine 32Bit-Firmware für RepRap 3D-Drucker 03. June 2016 12:01 |
