melt / sag print head easy fix January 18, 2014 09:57AM |
Re: melt / sag print head easy fix January 18, 2014 10:41AM |
tru168
Some of Ormerod users experienced overheat screws which will melt the print head holder . I apply silicone heat transfer compound in between cooling block surface and heat sink. The heat from cooling block transfer to heat sink very quickly and tested several hours of printing and the two screws are cool to touch.
Ew
Re: melt / sag print head easy fix January 18, 2014 10:50AM |
Re: melt / sag print head easy fix January 18, 2014 11:22AM |
tru168
Ew
Re: melt / sag print head easy fix January 18, 2014 11:41AM |
tru168
TMD:
Try it, you can feel the deference before and after. I used just sparingly to avoid dirty heatsink.
Ew
Re: melt / sag print head easy fix January 18, 2014 12:33PM |
Ian
Use the two screws into the cooling block to hold all five major pieces together. If you have it you can put a little heatsink compound between the cooling block and the heatsink.
Re: melt / sag print head easy fix January 18, 2014 01:28PM |
Re: melt / sag print head easy fix January 18, 2014 01:52PM |
tru168
I didn't see that instruction when I assemble mine.
Re: melt / sag print head easy fix January 18, 2014 11:58PM |
Re: melt / sag print head easy fix January 19, 2014 06:43AM |
Re: melt / sag print head easy fix January 19, 2014 12:00PM |
droftarts
So long as there's good contact between the heatsink and the aluminium heater block, there shouldn't be any great need for extra compounds between them; I don't usually worry about it. They're both aluminium, and conduct heat rapidly. Thermal paste such as Arctic Silver has an upper heat limit, which we exceed, so the paste may dry out and be a BARRIER to heat transfer:
From the Arctic Silver site: [www.arcticsilver.com]
Extended Temperature Limits:
Peak: –50°C to >180°C
Long-Term: –50°C to 130°C
Re: melt / sag print head easy fix January 19, 2014 12:05PM |
