Is there a easy way to cancel the prints and start over again immediately. July 25, 2014 12:09AM |
Re: Is there a easy way to cancel the prints and start over again immediately. July 25, 2014 01:40AM |
Re: Is there a easy way to cancel the prints and start over again immediately. July 25, 2014 02:39AM |
Re: Is there a easy way to cancel the prints and start over again immediately. July 25, 2014 02:45AM |
Re: Is there a easy way to cancel the prints and start over again immediately. July 25, 2014 09:40AM |
Re: Is there a easy way to cancel the prints and start over again immediately. July 25, 2014 05:03PM |
Re: Is there a easy way to cancel the prints and start over again immediately. July 25, 2014 09:13PM |
Re: Is there a easy way to cancel the prints and start over again immediately. July 25, 2014 10:51PM |
Re: Is there a easy way to cancel the prints and start over again immediately. July 26, 2014 08:36PM |
KimBrown
Also had it that it'll accept the homex, and homey fine, then the machine will hang when I want to homez, (I've removed the wait for temp line from the g file), then instead of lowering to the table to touch the glass, it goes up, then up again...
Re: Is there a easy way to cancel the prints and start over again immediately. July 27, 2014 03:23AM |
Re: Is there a easy way to cancel the prints and start over again immediately. July 27, 2014 05:23AM |
jstck
I've done the pause-reset thing a few dozen times, and twice or so I have had it do strange things. Last time (which was yesterday), it did the X&Y homing, seemed to skip Z altogether (it was at enough height that it should have worked normally), and when it started printing it was just moving around very quickly and not actually moving the extruder, as if only doing the travel moves or something.
Re: Is there a easy way to cancel the prints and start over again immediately. July 28, 2014 03:00AM |
dc42
jstck
I don't know why it skipped Z homing, however moving the head around without extruding suggests that you didn't have a T1 command in the gcode file you were printing.
