The Stupidly Tall-merod July 17, 2014 03:46PM |
Re: The Stupidly Tall-merod July 17, 2014 03:55PM |
Re: The Stupidly Tall-merod July 18, 2014 04:52AM |
Re: The Stupidly Tall-merod July 18, 2014 05:00AM |
Re: The Stupidly Tall-merod July 18, 2014 05:31AM |
static65
I'm also going to have to turn the accelerations down a bit I think, especially when I attempt tall prints!
I'll keep the updates coming when I get around to testing.
Re: The Stupidly Tall-merod July 18, 2014 05:40AM |
Re: The Stupidly Tall-merod July 18, 2014 08:19AM |
dc42
How long will it take you to lower the X axis to the bed?
Re: The Stupidly Tall-merod July 18, 2014 08:20AM |
Re: The Stupidly Tall-merod July 18, 2014 08:24AM |
Davek0974
Watch the speed on that Z-rod, too fast and with the nut at the bottom position, it could start whipping and bend.
Re: The Stupidly Tall-merod July 18, 2014 09:41AM |
Re: The Stupidly Tall-merod July 18, 2014 09:59AM |
Re: The Stupidly Tall-merod July 18, 2014 12:12PM |
Re: The Stupidly Tall-merod July 18, 2014 12:57PM |
Re: The Stupidly Tall-merod July 18, 2014 03:04PM |
Re: The Stupidly Tall-merod July 18, 2014 03:23PM |
Re: The Stupidly Tall-merod July 19, 2014 03:34AM |
static65
Nice! Is that an Iron Man arc reactor I see next to it?
Printing a 750mm vase now. It took me three attempts to find a scad script that didn't crash when I tried to generate a vase that high! Then I had issues with spiral vase mode in slic3r randomly missing one of the corners every now and then, which is a shame as it was really quick! It's now printing minus spiral vase mode. 3125 layers! Estimated 4 or 5 hours to completion. If it all works beautifully - perfect, but I'm more interested in seeing what can and maybe will go wrong at that height.
Re: The Stupidly Tall-merod July 19, 2014 04:54AM |
Re: The Stupidly Tall-merod July 19, 2014 05:00AM |
Re: The Stupidly Tall-merod July 19, 2014 05:14AM |
Re: The Stupidly Tall-merod July 19, 2014 05:27AM |
Re: The Stupidly Tall-merod July 19, 2014 05:42AM |
Davek0974
One other thing to look out for when you start tweaking speeds is the y axis acceleration, too much and with a tall print on the be, inertia could break the joint at the bed level and it'll fall over.
Re: The Stupidly Tall-merod July 19, 2014 06:20AM |
Re: The Stupidly Tall-merod July 19, 2014 09:02AM |
Re: The Stupidly Tall-merod July 19, 2014 09:52AM |
static65
And to answer an earlier question properly: homing Z from 750mm took a full 13 minutes and 48 seconds How do I up the homing speed? It seems to be encapsulated in a G30 command, but I'm sure there's an M value i can change somewhere... I reckon I should be able to double it without issue.
Re: The Stupidly Tall-merod July 20, 2014 05:17AM |
Re: The Stupidly Tall-merod July 20, 2014 05:31AM |
Re: The Stupidly Tall-merod July 20, 2014 06:53AM |
Re: The Stupidly Tall-merod July 20, 2014 10:14AM |
Re: The Stupidly Tall-merod July 20, 2014 10:37AM |
Re: The Stupidly Tall-merod July 20, 2014 10:53AM |
