Pause -> Resume -> Pause = dead! (0.96i-zpl, Web 1.08) December 16, 2014 07:28PM |
00:33:49Print paused! 00:33:54Print resumed! 00:43:18Disconnected Page not being updated 00:43:32M503 ; Configuration file for RepRap Ormerod ; RepRapPro Ltd ; M111 S0 ; *Debug off M550 PMy RepRapPro Ormerod ; *Machine name (can be anything you like) M551 Preprap ; *Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; *MAC Address M552 P192.168.0.99 ; *IP address M553 P255.255.255.0 ; *Netmask M554 P192.168.0.1 ; *Gateway M555 P2 ; *Set output to look like Marlin G21 ; *Work in millimetres G90 ; *Send absolute coordinates... M83 ; *...but relative extruder moves M906 X800 Y1000 Z800 E800 ; *Set motor currents (mA) M569 P0 S1 ; Reverse the X motor M563 P1 D0 H1 ; Define tool 1 G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures ;M563 P2 D1 H2 ; Define tool 2 (un-comment this for dual nozzle machines) ;G10 P2 S0 R0 ; Set tool 2 operating and standby temperatures (un-comment this for dual nozzle machines) M92 E467:467 ; *Set extruder steps per mm M558 P1 ; *Use an unmodulated Z probe or an intelligent Z probe G31 Z1.75 P675 ; *Set the probe height and threshold (put your own values here) M305 P0 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction M305 P2 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction M557 P0 X60 Y0 ; Four... M557 P1 X60 Y165 ; ...probe points... M557 P2 X222 Y165 ; ...for bed... M557 P3 X222 Y0 ; ...levelling ;M557 P4 X141 Y82.5 ; 5th probe point for levelling (un-comment this if you are using a differential IR probe) M556 S78 X0 Y0 Z0 ; Put your axis compensation here M201 X800 Y800 Z15 E1000 ;
Re: Pause -> Resume -> Pause = dead! (0.96i-zpl, Web 1.08) December 17, 2014 05:10AM |
Re: Pause -> Resume -> Pause = dead! (0.96i-zpl, Web 1.08) December 18, 2014 02:18PM |
zombiepantslol
Sorry to hear you're having problems. Can you send me the G-Code file you're having issues with? I'd then try to reproduce the problem you reported and fix it if I find out what's going on. Does it matter where you pause the print?
Also note you should put the right macros (pause.g, resume.g and reset.g) in your /sys directory. They can be found in the SD-image directory on my GitHub repository.
