Confused with the temperature of active and standby May 05, 2015 10:19PM |
Re: Confused with the temperature of active and standby May 07, 2015 05:31AM |
Re: Confused with the temperature of active and standby May 07, 2015 05:54AM |
sevenljy
However,the temperature can not get up enough when the heater has changed.Then the heater get stuck.
Re: Confused with the temperature of active and standby May 07, 2015 06:32AM |
Re: Confused with the temperature of active and standby May 07, 2015 06:44AM |
Re: Confused with the temperature of active and standby May 07, 2015 07:03AM |
Re: Confused with the temperature of active and standby May 07, 2015 07:10AM |
Re: Confused with the temperature of active and standby May 07, 2015 07:22AM |
Re: Confused with the temperature of active and standby May 07, 2015 07:39AM |
; tpre0.g ; Put G/M Codes in here to run when Tool 0 is freed G1 X1 Y205 F6000 ; tpost0.g ; Put G/M Codes in here to run after Tool 0 is selected M116 P0 ; tpre1.g ; Put G/M Codes in here to run when Tool 1 is freed G1 X1 Y205 F6000 ; tpost1.g ; Put G/M Codes in here to run after Tool 1 is selected M116 P1
Re: Confused with the temperature of active and standby May 07, 2015 08:55AM |
