So far out of touch, assistance please... December 24, 2015 06:14AM |
Re: So far out of touch, assistance please... December 24, 2015 07:07AM |
Re: So far out of touch, assistance please... December 24, 2015 08:02AM |
Re: So far out of touch, assistance please... December 24, 2015 08:57AM |
Re: So far out of touch, assistance please... December 24, 2015 09:31AM |
Re: So far out of touch, assistance please... December 24, 2015 10:15AM |
Re: So far out of touch, assistance please... December 24, 2015 10:26AM |
Re: So far out of touch, assistance please... December 24, 2015 10:29AM |
Re: So far out of touch, assistance please... December 24, 2015 10:49AM |
Re: So far out of touch, assistance please... December 24, 2015 10:51AM |
Davek0974
Ok, thanks, I have just tried again and this time after a bit of messing around in the command line app I have managed to flash and get a good response back.
I did not know you could drag and drop into command line on mac, I pasted the command from the thread linked, erased the word bossac, then dropped my bossac file onto the editor and it filled in the location of the app properly, then i erased the upload file name and dropped the new file from my desktop in so it filled in the name correctly and pressed enter - it worked. The tty port was the one listed as tty.modem1421 on my setup.
Now, my next issue - I can get a good ping so i loaded up the browser page and this time it looked perfect again BUT the connect button just switches from Connect to Retrying, no connection is happening.
Any ideas here??
Re: So far out of touch, assistance please... December 24, 2015 11:02AM |
Re: So far out of touch, assistance please... December 24, 2015 11:12AM |
dougal1957
Davek0974
Any ideas here??
Have you also updated the Web files on the SD Card (You need CH's DWC 1.07) DWC1.07
Re: So far out of touch, assistance please... December 24, 2015 11:13AM |
dc42
As well as the new www files, you will need to update config.g. See the sample config.g file in my repo for the Ormerod 1. I suggest you compare it with your own and add any missing lines, in particular you need the M574 line. You will also want pause.g and resume.g.
Re: So far out of touch, assistance please... December 24, 2015 11:39AM |
RepoQuote
Davek0974
dc42
Have you got a link, not sure where the 'repo' is
Davek0974
Thanks
Re: So far out of touch, assistance please... December 24, 2015 12:07PM |
Re: So far out of touch, assistance please... December 24, 2015 02:55PM |
Re: So far out of touch, assistance please... December 24, 2015 03:07PM |
Re: So far out of touch, assistance please... December 29, 2015 06:52AM |
Re: So far out of touch, assistance please... December 29, 2015 07:08AM |
Davek0974
Ok
finally got another chance to play around
The X axis is now running in the right direction but the homing limit switch does not work anymore, this is using DC42's modulated IR board.
Any ideas??
Re: So far out of touch, assistance please... December 29, 2015 07:15AM |
Re: So far out of touch, assistance please... December 29, 2015 09:44AM |
Re: So far out of touch, assistance please... December 30, 2015 01:23AM |
Davek0974
I only have a blue wire on that connector strip, moved it to pin5
still not working
Re: So far out of touch, assistance please... December 30, 2015 04:49AM |
Re: So far out of touch, assistance please... December 30, 2015 05:29AM |
Re: So far out of touch, assistance please... December 30, 2015 11:56AM |
Re: So far out of touch, assistance please... December 30, 2015 12:33PM |
Re: So far out of touch, assistance please... December 30, 2015 01:16PM |
Re: So far out of touch, assistance please... December 30, 2015 03:17PM |
Davek0974
I have the X, Y, Z homing OK using the individual buttons but the HomeAll code is duff and does not seem to work
Re: So far out of touch, assistance please... December 30, 2015 03:26PM |
Re: So far out of touch, assistance please... December 31, 2015 09:32AM |
